Automatic Failover?
Carl Harbeck
Hi all,
So I have a campus with two buildings, and each building has their own MPLS link. Also, these buildings have a microwave connection between them.
I'm looking for a way to utilize the microwave link to route local traffic between the buildings, but not MPLS traffic.
While I'm pretty solid with a manual solution for this scenario, I was hoping someone would be able to offer some advice for an automatic solution..
Any takers?
Giuseppe Larosa
Hello Carl,
you haven't provided a key information that is how is routing performed over the two MPLS links:
are you using static routes pointing at PE IP address or a dynamic routing protocol?
In any case, the fist factor to look at is how specific are routes learned on the MPLS link about the other site IP subnets.
If you are able to learn more specific routes over the microwave links you can achieve your objective leaving the MPLS link free to be used to reach other destinations.
I guess with automatic failover you mean the use of a routing protocol.
For this kind of scenario EIGRP can be used between Cisco devices.
A common IP subnet is needed on the microwave links
10.10.130.0/30 can be the microwave link
10.10.0.0/17 can be the aggregate of routes of first site
10.20.0.0/17 the aggregate of second site
R1
router eigrp 100
network 10.10.0.0  0.127.255.255
network 10.10.130.0 0.0.0.3
no auto-summary
R2 on site 2:
router eigrp 100
network 10.20.0.0  0.127.255.255
no auto-summary
EIGRP AS (100) must match in order to build a correct neighborship
the microwave link is used for all specific IP subnets if over the MPLS link only the aggregate address (10.20.0.0/17 for site2, 10.10.0.0/17 for site1) is received
Hope to help
Giuseppe
Giuseppe Larosa
Hello Carl,
R1
router eigrp 100
no auto-summary
R2 on site 2:
router eigrp 100
no auto-summary
Hope to help
Giuseppe
Hi Guiseppe,
The microwave and MPLS router for each building plug into a core switch. Internally we are using EIGRP and are using BGP in the MPLS cloud.
In discussing that further, your answer is what we will be doing, so thanks (clearly I am still new at this ).
Each site will go to their MPLS for outbound connections, and internally it will use the microwave since it is less hops. Should one of the MPLS links fail, it will use the less efficient (outbound) microwave route as an alternative.
Hello Carl,
if you want to use the microwave link as a backup when MPLS link fails you may need additional configuration like a default  route sent in EIGRP and redistribution of EIGRP into BGP in order to ensure that return traffic can come back or you need also to update NAT configuration at site 2 to accomodate also IP subnets of site1 and viceversa if you use the MPLS link also for internet access.
Hope to help
Giuseppe
