Highlighted
Beginner
Aux to Aux port connection
hi guys, i am not able to workout the solution of the problem below, kindly help me out
i have connected 2 routers to 2 external modems of us robotics through their aux ports, and then RA's modem is connected toa phone line which extension is 123, in the same way with RB with extension 543.
this was the configuration that i did on both routers
RA
hostname RA
int loopback 0
ip address 10.0.0.1 255.0.0.0
int async 1
ip address 1.1.1.1 255.255.255.0
dialer-group 1
dialer in-band
dialer string 543
async mode interactive
access-list 111 per ip any any
dialer-list 1 protocol ip list 111
ip route 20.0.0.0 255.0.0.0 1.1.1.2
ip route 1.1.1.2 255.255.255.255 async 1
line aux 0
modem inout
transport input all
transport output all
modem autoconfigure discovery
RB
hostname RB
int loopback 0
ip address 20.0.0.1 255.0.0.0
int async 1
ip address 1.1.1.2 255.255.255.0
dialer-group 1
dialer in-band
dialer string 123
ip route 10.0.0.0 255.0.0.0 1.1.1.1
ip route 1.1.1.1 255.255.255.255 async 1
line aux 0
modem inout
transport input all
now if i initiate ping from RA to 20.0.0.1 (RB loopback ) it tries to connect to the other end and it does!!!, but i m not able to get the successful ping, in debug it shows this
DDR: No free dialer - starting fast idle timer
i checked the cisco site and it says that this issue is related to dialer pool command which is configured under interface dialer, but i m not using int dialer !! so is it ESSENTIAL to use int dialer ?? or can i still do without it coz a guy told me that we dont need dialer interfaces, kindly tell me if there is any mistake in my config, or plz refer me a working cisco config that solves my issue,
thanks
1 REPLY 1
Highlighted
Contributor
Re: Aux to Aux port connection
here is a working config
hostname router1
username router2 password passwd
chat-script default "" ATDT\T TIMEOUT 60 CONNECT \c
interface Ethernet0
ip address 194.x.x.254 255.255.255.0
interface async1
ip address 192.1.1.2 255.255.255.0
encapsulation ppp
dialer in-band
dialer string 847846
dialer map ip 192.1.1.1 name router2 modem-script default 847846
dialer enable-timeout 8
dialer idel-timeout 300
dialer-group 1
async mode dedicated
ppp authentication chap
ip classless
ip route 193.x.x.0 255.255.255.0 192.1.1.1
dialer-list 1 protocol ip permit
line aux0
script dialer default
modem InOut
modem autoconfigure type usr_courier
transport input all
stopbits 1
flowcontrol hardware
Speed 115200
