Need some help. I've got a successful site-to-site VPN connection running. All traffic flows as it should, except I cannot ping from Azure VMs to my on-prem VMs. For example, if I ping from on-prem (i.e. 192.168.1.90) to Azure VM (10.0.0.1), it works. If I ping from Azure VM (i.e. 10.0.0.4) to on-prem (192.168.1.90) I get request timed out. All other traffic flows correctly. Just can't ping from Azure VMs to local ips. I can ping from Azure VM to WAN addresses, like google.com. Wondering if someone could tell me if something is up with my config. I have added exclusions for ICMP in Windows Firewalls on both sides and Azure NSGs, so that can't be it.
Here is my config (anything marked [removed] has been deemed sensitive):
Result of the command: "show run"
: Saved
: Serial Number: [removed]
: Hardware: ASA5506, 4096 MB RAM, CPU Atom C2000 series 1250 MHz, 1 CPU (4 cores)
ASA Version 9.8(2)
hostname ciscoasa
domain-name [removed]
enable password [removed]
xlate per-session deny tcp any4 any4
names
interface GigabitEthernet1/1
description Comcast
nameif outside
security-level 0
ip address [removed] 255.255.255.248
interface GigabitEthernet1/2
bridge-group 1
nameif inside_1
security-level 100
interface GigabitEthernet1/3
bridge-group 1
nameif inside_2
security-level 100
interface GigabitEthernet1/4
bridge-group 1
nameif inside_3
security-level 100
interface GigabitEthernet1/5
bridge-group 1
nameif inside_4
security-level 100
interface GigabitEthernet1/6
bridge-group 1
nameif inside_5
security-level 100
interface GigabitEthernet1/7
bridge-group 1
nameif inside_6
security-level 100
interface GigabitEthernet1/8
bridge-group 1
nameif inside_7
security-level 100
interface Management1/1
management-only
no nameif
no security-level
no ip address
interface BVI1
description [Removed] Network
nameif inside
security-level 100
ip address 192.168.1.254 255.255.255.0
boot system disk0:/asa982-lfbff-k8.SPA
ftp mode passive
clock timezone CST -6
clock summer-time CDT recurring
dns domain-lookup outside
dns server-group DefaultDNS
name-server 75.75.75.75
name-server 8.8.8.8
name-server 8.8.4.4
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
object network obj_any
subnet 0.0.0.0 0.0.0.0
object network inside-network
subnet 192.168.1.0 255.255.255.0
object network azure
subnet 10.0.0.0 255.255.0.0
object network DHCP_server
host 192.168.1.10
object service tcp[removed]
service tcp destination eq [removed]
description RDP
object network OutsideInterface
host [removed]
object service RDP-Service
service tcp source eq [removed]
object network AzureDC1
host 10.0.0.4
object service ICMPv4
service icmp echo 0
object-group network azure-networks
network-object object azure
object-group network onprem-networks
network-object 192.168.1.0 255.255.255.0
object-group service rdp tcp
port-object eq [removed]
access-list outside_access_in extended permit icmp any any
access-list outside_access_in extended permit ip host [removed] host [removed]
access-list outside_access_in remark Ping
access-list outside_cryptomap extended permit ip object-group onprem-networks object-group azure-networks
access-list outside_nat extended permit tcp any host [removed] eq [removed]
access-list inside_nat0_outbound extended permit ip 192.168.1.0 255.255.255.0 object azure
access-list OUTSIDE extended permit icmp any any
access-list inside_6_access_in extended permit ip any any
access-list inside_6_access_in extended permit icmp any any
pager lines 24
logging enable
logging buffer-size 1000000
logging buffered informational
logging asdm informational
mtu outside 1500
mtu inside_1 1500
mtu inside_2 1500
mtu inside_3 1500
mtu inside_4 1500
mtu inside_5 1500
mtu inside_6 1500
mtu inside_7 1500
icmp unreachable rate-limit 1 burst-size 1
icmp permit any outside
icmp permit any inside_2
icmp permit any inside_5
icmp permit any inside_6
asdm image disk0:/asdm-782-151.bin
no asdm history enable
arp timeout 14400
no arp permit-nonconnected
arp rate-limit 16384
nat (inside_1,outside) source static onprem-networks onprem-networks destination static azure-networks azure-networks
nat (inside_2,outside) source static onprem-networks onprem-networks destination static azure-networks azure-networks
nat (inside_3,outside) source static onprem-networks onprem-networks destination static azure-networks azure-networks
nat (inside_4,outside) source static onprem-networks onprem-networks destination static azure-networks azure-networks
nat (inside_5,outside) source static onprem-networks onprem-networks destination static azure-networks azure-networks
nat (inside_6,outside) source static onprem-networks onprem-networks destination static azure-networks azure-networks
nat (inside_7,outside) source static onprem-networks onprem-networks destination static azure-networks azure-networks
nat (any,outside) dynamic interface
access-group outside_access_in in interface outside
access-group inside_6_access_in in interface inside_6
route outside 0.0.0.0 0.0.0.0 [removed] 1
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 sctp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
timeout conn-holddown 0:00:15
timeout igp stale-route 0:01:10
user-identity default-domain LOCAL
user-identity ad-agent active-user-database on-demand
aaa authentication http console LOCAL
aaa authentication ssh console LOCAL
aaa authentication telnet console LOCAL
aaa authentication login-history
http server enable
http 192.168.1.0 255.255.255.0 inside_1
http 192.168.1.0 255.255.255.0 inside_2
http 192.168.1.0 255.255.255.0 inside_3
http 192.168.1.0 255.255.255.0 inside_4
http 192.168.1.0 255.255.255.0 inside_5
http 192.168.1.0 255.255.255.0 inside_6
http 192.168.1.0 255.255.255.0 inside_7
no snmp-server location
no snmp-server contact
sysopt connection tcpmss 1318
sysopt connection preserve-vpn-flows
service sw-reset-button
crypto ipsec ikev2 ipsec-proposal AES256Azure
protocol esp encryption aes-256
protocol esp integrity sha-1
crypto ipsec ikev2 ipsec-proposal DES
protocol esp encryption des
protocol esp integrity sha-1 md5
crypto ipsec ikev2 ipsec-proposal 3DES
protocol esp encryption 3des
crypto ipsec ikev2 ipsec-proposal AES192
protocol esp encryption aes-192
crypto ipsec security-association lifetime seconds 3600
crypto ipsec security-association lifetime kilobytes 102400000
crypto ipsec security-association pmtu-aging infinite
crypto map outside_map1 1 match address outside_cryptomap
crypto map outside_map1 1 set pfs group24
crypto map outside_map1 1 set peer [removed]
crypto map outside_map1 1 set ikev2 ipsec-proposal AES256Azure
crypto map outside_map1 1 set security-association lifetime seconds 3600
crypto map outside_map1 1 set security-association lifetime kilobytes 102400000
crypto map outside_map1 interface outside
crypto ca trustpoint _SmartCallHome_ServerCA
no validation-usage
crl configure
crypto ca trustpool policy
crypto ca certificate chain _SmartCallHome_ServerCA
certificate ca [removed]
quit
crypto ikev2 policy 1
encryption aes-256
integrity sha
group 24
prf sha
lifetime seconds 28800
crypto ikev2 enable outside
crypto ikev2 enable inside_1
crypto ikev2 enable inside_2
crypto ikev2 enable inside_3
crypto ikev2 enable inside_4
crypto ikev2 enable inside_5
crypto ikev2 enable inside_6
crypto ikev2 enable inside_7
crypto ikev1 enable outside
crypto ikev1 enable inside_1
crypto ikev1 enable inside_2
crypto ikev1 enable inside_3
crypto ikev1 enable inside_4
crypto ikev1 enable inside_5
crypto ikev1 enable inside_6
crypto ikev1 enable inside_7
crypto ikev1 policy 20
authentication rsa-sig
encryption aes-256
hash sha
group 2
lifetime 86400
crypto ikev1 policy 30
authentication pre-share
encryption aes-256
hash sha
group 2
lifetime 86400
crypto ikev1 policy 50
encryption aes-192
hash sha
group 2
lifetime 86400
crypto ikev1 policy 60
encryption aes-192
hash sha
group 2
lifetime 86400
crypto ikev1 policy 80
encryption aes
hash sha
group 2
lifetime 86400
crypto ikev1 policy 90
encryption aes
hash sha
group 2
lifetime 86400
crypto ikev1 policy 110
encryption 3des
hash sha
group 2
lifetime 86400
crypto ikev1 policy 120
encryption 3des
hash sha
group 2
lifetime 86400
crypto ikev1 policy 140
encryption des
hash sha
group 2
lifetime 86400
crypto ikev1 policy 150
encryption des
hash sha
group 2
lifetime 86400
telnet 192.168.1.0 255.255.255.0 inside_1
telnet 192.168.1.0 255.255.255.0 inside_2
telnet 192.168.1.0 255.255.255.0 inside_3
telnet 192.168.1.0 255.255.255.0 inside_4
telnet 192.168.1.0 255.255.255.0 inside_5
telnet 192.168.1.0 255.255.255.0 inside_6
telnet 192.168.1.0 255.255.255.0 inside_7
telnet timeout 5
no ssh stricthostkeycheck
ssh 192.168.1.0 255.255.255.0 inside_1
ssh 192.168.1.0 255.255.255.255 inside_2
ssh 192.168.1.0 255.255.255.255 inside_3
ssh 192.168.1.0 255.255.255.255 inside_4
ssh 192.168.1.0 255.255.255.255 inside_5
ssh 192.168.1.0 255.255.255.255 inside_6
ssh 192.168.1.0 255.255.255.255 inside_7
ssh timeout 5
ssh key-exchange group dh-group1-sha1
console timeout 0
dhcpd dns 75.75.75.75 75.75.76.76
dhcpd domain [removed]
dhcpd auto_config outside
threat-detection basic-threat
threat-detection statistics
threat-detection statistics tcp-intercept rate-interval 30 burst-rate 400 average-rate 200
group-policy GroupPolicy1 internal
group-policy GroupPolicy1 attributes
vpn-tunnel-protocol ikev2
dynamic-access-policy-record DfltAccessPolicy
username [removed]
username [removed]
tunnel-group [removed] type ipsec-l2l
tunnel-group [removed] general-attributes
default-group-policy GroupPolicy1
tunnel-group [removed] ipsec-attributes
ikev2 remote-authentication pre-shared-key [removed]
ikev2 local-authentication pre-shared-key [removed]
no tunnel-group-map enable ou
class-map class-default-settings
match default-inspection-traffic
class-map global-class
match any
class-map inspection_default
policy-map type inspect dns preset_dns_map
parameters
message-length maximum client auto
message-length maximum 512
no tcp-inspection
policy-map global_policy
class inspection_default
inspect icmp
policy-map global-policy
class class-default-settings
inspect icmp
policy-map class-default
class global-class
inspect icmp
service-policy global_policy global
prompt hostname context
service call-home
call-home reporting anonymous
call-home
contact-email-addr mark.bell@journeystn.org
profile CiscoTAC-1
destination address http
https://tools.cisco.com/its/service/oddce/services/DDCEService destination address email callhome@cisco.com
destination transport-method http
subscribe-to-alert-group diagnostic
subscribe-to-alert-group environment
subscribe-to-alert-group inventory periodic monthly
subscribe-to-alert-group configuration periodic monthly
subscribe-to-alert-group telemetry periodic daily
hpm topN enable
Cryptochecksum:426c1042e5da8735c3d46dba6a161aec
: end
