Azure to ASA to Internet
I have successfully created the site to site between our ASA to Azure.
Azure can see our internal traffic and use the resources.
My question is, how can I make Azure goes through our ASA for internet?
Azure > ASA > Internet?
I have added it into our site to site connection for i.e the Azure VM. However it still didn't work - i have added into the ACL too.
Do I need a return ACL / NAT for it to work?
26 Replies 26
Georg Pauwen
VIP Master VIP Master
VIP Master
looking at your config again, it looks like you are missing a few things still. Add the lines in bold:
interface GigabitEthernet1/1
channel-group 10 mode active
no nameif
no security-level
no ip address
interface GigabitEthernet1/2
no nameif
no security-level
no ip address
interface GigabitEthernet1/3
channel-group 20 mode active
no nameif
no security-level
no ip address
interface GigabitEthernet1/4
no nameif
no security-level
no ip address
interface GigabitEthernet1/5
interface GigabitEthernet1/6
interface GigabitEthernet1/7
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet1/8
shutdown
no nameif
no security-level
no ip address
interface Management1/1
management-only
nameif management
security-level 0
interface Port-channel10
lacp max-bundle 8
no nameif
no security-level
no ip address
interface Port-channel10.200
no nameif
no security-level
no ip address
interface Port-channel10.3001
vlan 3001
nameif outside-isp1
security-level 0
ip address 115.42.250.6 255.255.255.248
interface Port-channel10.3002
vlan 3002
nameif outside-isp2
security-level 0
ip address 118.189.59.68 255.255.255.248
interface Port-channel20
lacp max-bundle 8
no nameif
no security-level
no ip address
interface Port-channel20.20
vlan 2020
nameif inside
security-level 100
ip address 10.0.20.254 255.255.255.248 standby 10.0.20.253
dns domain-lookup outside-isp1
dns server-group DefaultDNS
name-server 8.8.8.8
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
object network yahoo.com
host 106.10.248.151
description yahoo.com
object-group network obj-local
description Azure to Office
network-object 10.0.0.0 255.255.0.0
network-object object yahoo.com
object-group network obj-remote
description AZURE
network-object 10.100.0.0 255.255.0.0
access-list azure-map extended permit ip object-group obj-local object-group obj-remote
access-list outside-isp2_cryptomap_2 permit ip any 10.100.0.0 255.255.0.0
mtu management 1500
mtu dmz 1500
mtu outside-isp1 1500
mtu outside-isp2 1500
mtu inside 1500
nat (inside,outside-isp2) source static obj-local obj-local destination static obj-remote obj-remote
nat (inside,outside-isp2) dynamic interface <-- add this to obj-local
nat (outside-isp2,outside-isp2) dynamic interface <-- add this to obj-remote
route outside-isp1 0.0.0.0 0.0.0.0 115.42.250.6 1 track 1
route outside-isp1 10.0.0.0 255.0.0.0 115.42.250.6 1 track 1
route outside-isp2 0.0.0.0 0.0.0.0 118.189.59.68 10
route outside-isp2 10.0.0.0 255.0.0.0 118.189.59.68 10
crypto ipsec ikev1 transform-set aes-sha-hmac esp-aes esp-sha-hmac
crypto ipsec ikev1 transform-set azure-ipsec-proposal-set esp-aes-256 esp-sha-hmac
crypto ipsec ikev2 ipsec-proposal AZURE
protocol esp encryption aes-256
protocol esp integrity sha-256
crypto ipsec security-association lifetime seconds 3600
crypto ipsec security-association lifetime kilobytes 102400000
crypto ipsec security-association pmtu-aging infinite
crypto map outside-isp2_map0 1 match address outside-isp2_cryptomap_2
crypto map outside-isp2_map0 1 set peer 52.187.32.142
crypto map outside-isp2_map0 1 set ikev1 transform-set azure-ipsec-proposal-set
crypto map outside-isp2_map0 1 set reverse-route
crypto map outside-isp2_map0 interface outside-isp2
crypto isakmp identity address
crypto ikev2 policy 1
encryption aes-256
integrity sha256
group 14
prf sha256
lifetime seconds 86400
crypto ikev2 policy 10
encryption aes-192
integrity sha
group 5 2
prf sha
crypto ikev2 policy 20
encryption aes
integrity sha
group 5 2
prf sha
crypto ikev2 policy 30
encryption 3des
integrity sha
group 5 2
prf sha
crypto ikev2 policy 40
encryption des
integrity sha
group 5 2
prf sha
crypto ikev2 remote-access trustpoint SSL-TrustPoint
crypto ikev1 enable outside-isp1
crypto ikev1 enable outside-isp2
crypto ikev1 policy 5
authentication pre-share
encryption aes-256
hash sha
group 2
lifetime 86400
crypto ikev1 policy 10
encryption aes
hash sha
group 2
lifetime 86400
track 1 rtr 1 reachability
telnet timeout 5
error-recovery disable
vpn-tunnel-protocol ikev1 ikev2 ssl-client
split-tunnel-policy tunnelspecified
split-tunnel-network-list value POC-SPLIT-TUNNEL
dynamic-access-policy-record DfltAccessPolicy
tunnel-group 52.187.32.142 type ipsec-l2l
tunnel-group 52.187.32.142 ipsec-attributes
class-map inspection_default
match default-inspection-traffic
same, not working.
post the running config again with the changes you have configured...
Actually, take the routes to ISP1 out:
--> no route outside-isp1 0.0.0.0 0.0.0.0 115.42.250.6 1 track 1
--> no route outside-isp1 10.0.0.0 255.0.0.0 115.42.250.6 1 track 1
sorry, I was away to rebuild the entire setup. still, it doesn't work.
I have since removed all the changes and hope to start afresh.
Scenario remains the same.
I can see traffic from Azure to the internet hitting my firewall. However, it remains to drop.
Routing failed to locate next hop from outside-isp2: 10.88.0.99/15 to inside:106.10.250.11/0
adding a static route - u will not see this issue anymore, however, it remains the same, my Azure still couldn't load the site.
your routing doesn't look right. You are tracking the first default route, which means that the second default route to your isp2 will never get installed until the primary fails.
Test what happens if you leave just the two routes marked in bold:
route outside-isp1 0.0.0.0 0.0.0.0 115.42.250.5 1 track 1
route outside-isp1 10.0.0.0 255.0.0.0 115.42.250.5 1 track 1
route management 0.0.0.0 0.0.0.0 10.200.5.254 1
route outside-isp2 0.0.0.0 0.0.0.0 118.189.59.67
route outside-isp2 4.2.2.2 255.255.255.255 118.189.59.67
route outside-isp1 8.8.8.8 255.255.255.255 115.42.250.5 1
route outside-isp2 10.0.0.0 255.0.0.0 118.189.59.67 10
route inside 10.200.0.0 255.255.0.0 10.200.20.249 1
and remove the rest ?
Indeed. This is just for testing. Leave only the default route through ISP2 in there...
tried, doesnt work still.
i tried to change my site to site to use isp1. it doesnt work either.
site to site to internal resource is ok though
just for my understanding: do you have Internet connectivity at all ? Is ISP1 working ?
yeah, both line are up and running from internal to internet and based on my site to site i can see it is connected.
However for the internet traffic it only have Rx bytes received but Tx bytes remain at 0
seem like a tough 1.
Recognize Your Peers
