Highlighted
Beginner
Back to Back T1 config help
I have 2 routers, a 3640 with a t1 interface and a 2524 with a t1 interface. I made a back to back cable so that I could try to configure a test connection between the 2 routers. When I get them all turned on and configured I see the interfaces registered as Up/Down and I see alot of interface resets. Attached are the 2 configs... any ideas would be greatly appreciated.
2524 config:
version 12.3
service password-encryption
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
ip subnet-zero
interface Ethernet0
no ip address
shutdown
interface Serial0
bandwidth 1500000
ip address 192.168.1.2 255.255.255.0
no fair-queue
service-module t1 timeslots 1-24
interface Serial1
no ip address
shutdown
ip http server
ip classless
line con 0
line aux 0
line vty 0 4
login
3640 Config:
version 12.2
service timestamps debug uptime
service timestamps log uptime
hostname Router
memory-size iomem 20
ip subnet-zero
ip audit notify log
ip audit po max-events 100
call rsvp-sync
controller T1 1/0
framing esf
clock source internal
linecode b8zs
channel-group 1 timeslots 1-24
controller T1 1/1
framing sf
linecode ami
interface FastEthernet0/0
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0
no ip address
shutdown
clock rate 2000000
interface Serial0/1
no ip address
shutdown
clock rate 2000000
interface FastEthernet1/0
no ip address
shutdown
duplex auto
speed auto
interface Serial1/0:1
bandwidth 1500000
ip classless
no ip http server
dial-peer cor custom
line con 0
line aux 0
line vty 0 4
login
Thanks everyone,
LR
2 REPLIES 2
Highlighted
Advocate
A T1 crossover cable should be a UTP / Cat5(5e, 6) with pins 1&2 --> 4&5 on each end.
Like:
1 -->>4
2 -->>5
4 -->>1
5 -->>2
Make sure the cable is terminated properly and done well; een though the data rate is significantly less than Fast Ethernet, the signaling scheme for serial is sensitive to cable quality.
If you're talking about something like a 60pin --> 60 pin back-to-back cable, make sure you have the DCE end going to the router with the DCE role (and DTE to the DTE-side router). There (should be) are labels on each end of the cable to identify which end is which.
You can also do a "sh controllers" which should tell you what the router thinks the cable is.
Good Luck
Scott
Highlighted
Enthusiast
Off the 2524 router I see no framing and coding. if it is default it may not show it, however just need to ask if it was set for ESF/B8ZS. Also I see the clocking is set for Internal on one rouer and the other should be set for external timing. Again it may be default and may not be shown on the config. Also a show controllers will show any layer 1 errors (Red alarm, Yellow Alarm, etc...) Maybe your T-1 crossover cable is faulty...Just some items to check....
