Bad Routes in BGP.
Faizan Shaikh
How to determine the bad routes in BGP routing table?
csco10716389
Give some more details......what do you mean by BAD routes.
Giuseppe Larosa
Hello Faizan,
if you mean what routes you shouldn't accept on an eBGP session describing Internet the routes that shouldn't be accepted are called bogons:
you should at least:
deny = not accept your own public prefixes
deny = not accept any private IP address as per RFC 1918
see for more information
http://www.nanog.org/mtg-0501/pdf/deitrich.pdf
if instead you mean what routes are good in a BGP table just check the first lines of show ip bgp
installed routes are also present in the routing table in the BGP table are marked as:
example
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal
Origin codes: i - IGP, e - EGP, ? - incomplete
Network Next Hop Metric LocPrf Weight Path
*>i3.0.0.0 xx.yy.5.178 70 0 701 80 i
* zz.kk.234.137 70 0 3549 701 80 i
the first path is preferred
Hope to help
Giuseppe
Friends,
It would be more specific if i say 'Corrupt BGP routes'.
Thanx Giuseppe for your help, it helped me a lot.
