Estimados buenas tardes, estoy haciendo balanceo de carga tengo esta config y no me funciona es decir los usuarios salen por solo una interface, en esta config hay una VPDN que se conecta con Dialer ha un servidor remoto.
los clientes LAN estan saliendo por solo una interfaz, alguna correccion en esta config por favor me lo hacen saber, gracias
vpdn-group 1
request-dialin
protocol pptp
rotary-group 0
initiate-to ip IP_PUBLICA DEL SERVIDOR VPDN
interface FastEthernet0/0
description ## CONEXION LAN ##
ip address 10.20.0.1 255.255.255.0
ip nat inside
ip virtual-reassembly
load-interval 30
duplex auto
speed auto
interface FastEthernet0/1
description ## WAN ISP1 ##
ip address 2.7.5.2 255.255.255.240
ip nat outside
load-interval 30
duplex auto
speed auto
interface FastEthernet0/3/0
description ## WAN ISP2 ##
ip address 1.1.4.2 255.255.255.252
ip nat outside
load-interval 30
duplex auto
speed auto
interface Dialer0
mtu 1450
ip address negotiated
ip pim dense-mode
encapsulation ppp
load-interval 30
dialer in-band
dialer idle-timeout 0
dialer string 123
dialer vpdn
dialer-group 1
no cdp enable
ppp pfc local request
ppp pfc remote apply
ppp chap hostname nombrehost
ppp chap password 7 xxxxxxxxxx
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 2.7.5.1
ip route 0.0.0.0 0.0.0.0 1.1.4.1 10
ip route 10.40.0.0 255.255.0.0 10.200.0.4
ip route 10.60.0.0 255.255.0.0 10.200.0.4
ip route 2.0.1.2 255.255.255.255 1.1.2.1 name conexiona servidor remoto por VPDN
ip http server
ip http access-class 23
ip http authentication local
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat translation timeout 200
ip nat translation tcp-timeout 200
ip nat translation udp-timeout 100
ip nat translation dns-timeout 65
ip nat translation max-entries all-host 300
ip nat inside source route-map ISP2 interface FastEthernet0/3/0 overload
ip nat inside source route-map ISP1 interface FastEthernet0/1 overload
ip nat inside source static tcp 1.2.0.4 22 2.7.5.2 7422 extendable
ip access-list extended NAT_LAN
permit ip 10.60.0.0 0.0.255.255 any
dialer-list 1 protocol ip permit
snmp-server community fua5tahi RO
route-map ISP2 permit 20
match ip address NAT_LAN
match interface FastEthernet0/3/0
set ip next-hop 1.1.4.1
route-map ISP1 permit 10
match interface FastEthernet0/1
set ip next-hop 2.7.5.1
