Bandwidth question
shanemcanuff
I have a quick question, is network bandwidth in Mb= Megabits or MB=Megabytes?
nkarpysh
Usually bandwidth specified in bits per second. So in this case MB- megabits per second.
Nik,
HTH,
Niko
Usually service providers will caliculate the link bandwidth in bigs per second.
So it is like 10 Mbps and 20 Mbps.
Please rate the helpful posts.
Naidu.
Joseph W. Doherty
Disclaimer
The    Author of this posting offers the information contained within this    posting without consideration and with the reader's understanding that    there's no implied or expressed suitability or fitness for any  purpose.   Information provided is for informational purposes only and  should not   be construed as rendering professional advice of any kind.  Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In    no event shall Author be liable for any damages whatsoever  (including,   without limitation, damages for loss of use, data or  profit) arising  out  of the use or inability to use the posting's  information even if  Author  has been advised of the possibility of such  damage.
Posting
As the other posters have already noted, network bandwidths are generally bits per second, bps.  However, this is also the maximum "raw" transfer rate.  When you account for all the required overhead for "packaging" actual data, the effective rate will be less, sometimes much less.
