Bandwidth support
nishchient
Which router supports 60 MB of Metro Ethernet Link. Please suggest.
Nishchient
lgijssel
Level 9
Level 9
You should be looking for a router that can reliably perform this task; that is without being loaded too heavy with just the forwarding. I would be quite satisfied with a 2821 or a 2851 for this task. If you have more to spend you can also go for the 3800 series.
regards,
Leo
HI, [Do Rate all HELPFUL POSTS]
If the Traffic pattern is Huge and Routing Table size need to handled in more means:
I would recommend 3800 Series Routers.
Refer link below for more INFO reg 3800:
http://www.cisco.com/en/US/products/ps5855/index.html
Routers ranging from 1800, 2800, 3800 Series Routers are best Suited for Branch Offices Environments.
Best Regards,
Guru Prasad R
Thanks for the reply.
following are details
1. Using 3825 Cisco Router.
2. 60 MB Pipe from Reliance.
3. FTP Data Transfer From Delhi - Bombay.
4. Utilisation above 60% 24 hrs.
5. delhi end - 3825 Gigabit Terminating Interface
6. Mumbai End - 7507 FastEthernet Terminating Interface.
As the utilisation is high on WAN, please do let me know that router which you suggest will handle this much of capacity will support.
Nishchient
