Basic BGP neighborship question
Hello guys,
I  am new to BGP and i would appreciate if someone can give me a hint on what is wrong with my config
Here is the topology
R1(BGP Router AS1)    -----   R2  ------ R3(BGP Router AS2)
i wanted to make R1 and R3  BGP neighbors. All routers are connected with Ethernet links
According to the topology they are not directly connected since they have R2 between them (R2 does not have any routing protocols activated).
R1 has a static route to R3 network via R2  and R3 has a static route to R1 network via R2.
Ping is working between R1 and R3.
After going through the most basic config for BGP , when typing the neighbor command in both routers they fail to become neighbors ,actually they dont even try. I took a packet capture  on R3 and R1 and i do not see any of them initiating   BGP sessions.
The config  on
R1:
router bgp 1
address-family ipv4 unicast
bgp router-id  (R1's router id)
neighbor  (R3's ip address)
R3:
router bgp 3
bgp router-id  (R3's router id)
neighbor  (R1's ip address)
Can someone explain what am i doing wrong?
R1
router bgp 1
neighbor R2 remote-as 3
neighbors R2 ebgp-multihop
ip route R2 serial or ethernet <-need this static route
R2
router bgp 3
neighbor R1 remote-as 1
neighbor R1 ebgp--multihop
ip route R1 serial or thereat <-need this static route
7 Replies 7
R1
router bgp 1
R2
router bgp 3
correct the AS number.
does this actually work ?
R1
router bgp 1
R2
router bgp 3
I was under the impression that there was no BGP configured on R2:
--> (R2 does not have any routing protocols activated).
you need to add ebgp multihop:
R1:
router bgp 1
neighbor (R3's ip address) ebgp-multihop 3
R3:
router bgp 3
neighbor (R1's ip address) ebgp-multihop 3
When i get to type  this command
this is the console message  "% Specify remote-as or peer-group commands first"
so i tried to do it like this
neighbor R3-ipaddress  R3-AS ebgp-multihop 3  and  then it give  me  an "Invalid input detected at '^' marker  where the  ebgp starts
valid"
Before you try the multi hop command you need to define the remote AS for the peer
neighbor R3 remote-as 3
Rick
R1:
router bgp 1
neighbor (R3's ip address) remote-as 3
R3:
router bgp 3
neighbor (R1's ip address) remote-as 1
