10-10-2006 05:24 PM - edited 03-03-2019 02:18 PM
If you see on the attached diagram,
according to an exercise I am doing I understand that RTC Router will not
receive 10.0.0.0 in its routing table.
Is that happening because the 'access-list 10 permit 192.168.10 0.0.0.255' permits advertisements for 192.168.10.0/24 goes through,
but there is an implicit deny that would 'block' 10.0.0.0 from going to Router RTC ? Is that the reason why RTC would not have 10.0.0.0 on its routing table ?
Solved! Go to Solution.
10-10-2006 06:56 PM
Marlon
Yes there is an implicit deny which will deny 10.0.0.0/8. And yes as soon as you implement a distribute-list which uses a standard access-list you should have permit statements for each network that you want to be advertised, otherwise they will be denied.
Rick
10-10-2006 05:34 PM
hi
permit the network 10.0.0.0/8 on the RTC.Becz as per ur config. 10.0.0.0 is deny,So u have to permit this network.pls update once done.
10-10-2006 06:29 PM
Rajeshc, you mean it is a deny for 10.0.0.0/8 because it is getting an implicit deny, right ?
That means that as a generic rule, as soon as I implement a distribute-list (which uses an access-list) I should list all networks I want to be permitted there, otherwise they would be denied ?
Thanks.
10-10-2006 06:51 PM
You are correct!!
RTC should only see 192.168.10.0/24 because it is the only network permitted in the ACL 10. The distribute-list only applies to EIGRP updates sent out S0/0 on RTB, so RTA should have a complete view of the EIGRP topology & RTC will only have information for the 192.168.10.0/24 network. The key in the distribute-list here is the direction it applies to.
10-10-2006 06:56 PM
Marlon
Rick
10-10-2006 07:12 PM
yes u r right.
10-11-2006 05:59 AM
Thanks !!! You guys are amazing !
