Basic PAT config help
jksnook
I am attempting to setup a basic PAT configuration on a 871. Is it possible to do this on a router that has a dynamic external IP address? Can anyone give me some feedback on how to make a PAT entry to send a specific port to an internal host?
lgijssel
Level 9
Level 9
Basically, there is not much too it:
int fa0
ip nat inside
int fa1
ip nat outside
ip nat inside source static tcp 10.1.1.1 80 80 extendable
The only catch is that you need to reconfigure the router when the dynamic ip changes.
regards,
Leo
So there is no way to set this up one time and not have to re-configure the nat statement everytime the dynamic IP changes?
roneng
if you are using dialer, you can do it with "overload" and it doesnt matter if the ip changes:
access-list 101 permit ip 192.168.1.0 0.0.0.255 any
ip nat inside source list 101 interface Dialer1 overload
and of course dont forget the nat inside outside commands.
