Basic Static Route Question
brianbhc1
We have a 1605 that we are trying the following:
Our ISP is providing a DSL circuit with a single public IP address 69.xx.xx.130.
We would like to assign that address to ethernet1 and then configure ethernet0 with an internal ip address 10.0.0.1. The gateway for the DSL is 69.xx.xx.1
So we set up the two interfaces successfully and can ping each of the interfaces, ip routing is running however we can see to get traffic from the private side to the ISP gateway.
We have tried the following:
ip route 69.xx.xx.0 255.255.255.0 69.xx.xx.1
ip route 10.0.0.0 255.0.0.0 69.xx.xx.1
ip route 0.0.0.0 0.0.0.0 eth1
All with no luck.
Thanks in advance,
Brian
Richard Burts
Before he posted it here Brian posted this same question on the LAN Routing and Switching forum where it has received a couple of responses. I suggest that any discussion of this question be consolidated in the LAN forum.
Rick
Rick
globalnettech
Level 5
Level 5
Hello Brian,
make sure your configuration looks like this. You do not need a static route to Ethernet 1, since the interface is directly connected:
version 12.2
hostname Router
logging queue-limit 100
no logging console
enable secret 5 yyyy
enable password xxxx
ip subnet-zero
no ip domain lookup
vpdn enable
vpdn-group 1
request-dialin
protocol pppoe
interface Ethernet0
ip address 10.1.1.1 255.255.255.0
no ip proxy-arp
ip nat inside
no ip route-cache
no ip mroute-cache
interface Ethernet1
no ip address
no ip proxy-arp
pppoe enable
pppoe-client dial-pool-number 1
no cdp enable
interface Dialer1
mtu 1492
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 1
ppp authentication pap callin
ppp pap sent-username aaaa@bbbb.com password 0 zzzzz
access-list 1 permit 10.1.1.0 0.0.0.255
ip nat inside source list 1 interface Dialer1 overload !
dialer-list 1 protocol ip permit
ip route 0.0.0.0 0.0.0.0 Dialer1
line con 0
line vty 0 4
login
end
If you cannot get your router to work with this configuration, can you post the one you have so far ?
GNT
