05-31-2017 10:18 PM - edited 03-05-2019 08:38 AM
05-31-2017 11:58 PM
hard to say, as this could be a spanning tree related problem as well. Post the configs of the L3 switches and the routers...
06-01-2017 06:05 AM
Agree with Georg that the disconnect problems may be a spanning tree issue.
By default, OSPF will send traffic across four equal cost paths. So if R1 is showing routes to VLAN 2 via both SW1 and SW2, chances are it sends to one for a while then the other. A lot depends on the amount of traffic. Wherever the asterisk is is the route that is being used.
You could force the traffic to SW1 by simply adjusting the OSPF link costs.
06-01-2017 05:03 PM
Is possible to share:
- the config of the routers and the switches
- Show ip route from each device
- show ip ospf neighbors from the switches.
Thank you in advance
