Best practice for loopback addresses
enyatoti
Where can I get information on how to assign loopback addresses in a large network, how to use loopback interfaces and so on?
maher
Hi there,
In my network, I use to monitor the router itself.Since the loopback interface never goes down, I monitor the router based on loopback address. If the loopback down,I will know that, one of my router is down.
regards,
maher
wchew
Loopback interface is also greatly in used for routing protocal. Example, in OSPF environment if a interface goes down OSPF will recalculate the routes and does a multicast flood to other routers.
Since loopback never down except router down, it is a good practices. I used them a lot during routing.
Best regards,
Lawrence
prashantsansare
THERE IS ONE cRITERIA u should keep in mind when giving lopback address in large Network when yu are using OSPF ,Yu have to check in the Requirement of higest IP address ,Because the highest IP address becames the DR
mlitka
Level 2
Level 2
I realize this was posted some years ago, but I am wondering what you ended up doing and if you found any additional information?
Does anyone else have a whitepaper or SRND they can reference?
