best practice in load balacing internet traffic using 2 ISP's.
cfajardo1_2
what is the BEST PRACTICE in load balacing internet traffic using 2 ISP's.
NOTES:
-web/mail servers are hosted
-single internet router
-Public IP address inside the internet router
OBJECTIVE:
-half of the internet traffic will go to the ISP1
-other half will go to ISP2
paolo bevilacqua
you cannot easily load balance with public address "inside". For this, you need BGP, and both ISP willing to route the network block you've been assigned (likely, by one ISP).
If you are OK with private addresses, you can load balance using NAT and that does not requires BGP.
paolo bevilacqua
mvsheik123
Level 7
Level 7
You can go with BGP. Use the 'weight' attribute to assign weights to routes (as this is single internet router). Please see the link below..
http://www.cisco.com/en/US/tech/tk365/technologies_configuration_example09186a00800945bf.shtml
hth
MS
