BFD Dampening
Philipeg1
Good day
A colleague and I are trying to configure BFD dampening on IE4000 switches. When we use the show commands we can see the dampening option however when in config term under BFD we have no such option.
License Level: ipservices
License Type: Permanent Right-To-Use
Next reload license Level: ipservices
cisco IE-4000-16GT4G-E (APM86XXX) processor (revision C0) with 1048576K bytes of
memory.
Processor board ID FDO1927U077
Last reset from power-on
17 Virtual Ethernet interfaces
20 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : 18:8B:9D:2B:8F:80
Motherboard assembly number     : 73-15761-04
Motherboard serial number       : xxxx
Model revision number           : C0
Motherboard revision number     : A0
Model number                    : IE-4000-16GT4G-E
System serial number            : xxxx
Top Assembly Part Number        : 800-40952-01
Top Assembly Revision Number    : D0
Version ID                      : V01
Hardware Board Revision Number  : 0x05
Backplane FPGA version          : 0.2E
CIP Serial Number               : 0x7E2B8F80
SKU Brand Name                  : Cisco
Switch Ports Model                     SW Version            SW Image
*    1 20    IE-4000-16GT4G-E          15.2(4)EA1            IE4000-UNIVERSALK9-M
 TSN-SWT-04(config-bfd)#?
BFD template configuration commands:
  authentication  Authentication type
  default         Set a command to its defaults
  echo            Use echo adjunct as bfd detection mechanism
  exit            Exit from BFD template configuration mode
  interval        Transmit interval between BFD packets
  no              Negate a command or set its defaults
 TSN-SWT-04#show bfd neighbors ?
  client         View neighbors of a specific client
  dampened       Display suppressed sessions information
  dampening      Display dampening information
  details        Display all BFD parameters
  hardware       Display hardware offloaded sessions
  inactive       Display inactive adjs
  ipv4           Neighbor IPv4 single-hop address
  ipv6           Neighbor IPv6 single-hop address
  mpls-pw        MPLS Pseudo-wire
  mpls-tp        MPLS TP
  multihop-ipv4  Multi-hop IPv4
  multihop-ipv6  Multi-hop IPv6
  vrf            Show entries for a VPN Routing/Forwarding instance
  |              Output modifiers
  <cr>
Francesco Molino
For me this is more a router feature.
But I was not sure at 100% that this feature isn't existing on IE-4000 switches, and I've checked.
If you take a look on Cisco IOS feature navigator (http://tools.cisco.com/ITDIT/CFN/jsp/by-feature-technology.jsp), you will see that it's available on ISR and ASR.
I've also checked on Cisco BFD dampening documentation (http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/iproute_bfd/configuration/xe-3s/irb-xe-3s-book/irb-bfd-damp.html) and it's available since version IOS 15.3(2)T. However, the latest IOS version for IE-4000 is 15.2.4-EA1(ED).
Hope this answered your question.
Thanks.
PS: don't forget to rate and mark as correct answer.
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
Hi Supportlan
No this does not answer the question. BFD is available on many platforms. When will the IOS version for IE-4000 have BFD dampening added to it ?
Philip
I don't know anything about this kind of roadmap. You may ask to your local cisco.
Sorry for that
Francesco
