BGP Advertisement
Norman123
I need some help with the following BGP configuration
router bgp 300
neighbor 192.169.10.1 remote-as 200
neighbor 192.169.10.1 description ISP-A
neighbor 192.169.20.1 remote-as 400
neighbor 192.169.20.1 description ISP-B
address-family ipv4
network 10.0.0.0 mask 255.255.255.0
network 20.0.0.0 mask 255.255.255.0
network 30.0.0.0 mask 255.255.255.0
network 40.0.0.0 mask 255.255.255.0
neighbor 192.169.20.1 activate
neighbor 192.169.20.1 next-hop-self
neighbor 192.169.20.1 soft-reconfiguration inbound
neighbor 192.169.20.1 prefix-list ISPBIn in
neighbor 192.169.20.1 route-map ISPBOut out
neighbor 192.169.10.1 activate
neighbor 192.169.10.1 next-hop-self
neighbor 192.169.10.1 weight 500
neighbor 192.169.10.1 soft-reconfiguration inbound
neighbor 192.169.10.1 route-map ISPAOut out
maximum-paths 4
exit-address-family
ip prefix-list ISPBIn seq 10 permit 0.0.0.0/0
ip prefix-list ISPBIn seq 100 deny 0.0.0.0/0 le 32
route-map ISPBOut permit 20
match ip address prefix-list ISPBPrimary
set origin incomplete
route-map ISPBOut permit 30
match ip address prefix-list ISPBBackup
set as-path prepend 300 300 300 300
route-map ISPAOut permit 10
match ip address prefix-list ISPAPrimary
route-map ISPAOut permit 20
match ip address prefix-list ISPABackup
ip prefix-list ISPBPrimary seq 20 permit 20.0.0.0/24
ip prefix-list ISPBPrimary seq 30 permit 30.0.0.0/24
ip prefix-list ISPBPrimary seq 40 permit 40.0.0.0/24
ip prefix-list ISPBPrimary seq 100 deny 0.0.0.0/0 le 32
ip prefix-list ISPBBackup seq 50 permit 10.0.0.0/24
ip prefix-list ISPBBackup seq 100 deny 0.0.0.0/0 le 32
ip prefix-list ISPAPrimary seq 5 permit 10.0.0.0/24
ip prefix-list ISPAPrimary seq 100 deny 0.0.0.0/0 le 32
ip prefix-list ISPABackup seq 8 permit 20.0.0.0/24
ip prefix-list ISPABackup seq 9 permit 30.0.0.0/24
ip prefix-list ISPABackup seq 10 permit 40.0.0.0/24
ip prefix-list ISPABackup seq 100 deny 0.0.0.0/0 le 32
______________________________________________
Want to achieve multiple of things
1- block 10.0.0.0/24 to be routed on ISP-A as primary and the rest 3 blocks on ISP-B if the two paths are up
2- if one of the path is down all blocks should be working on the active path
My configuration is not matching, there is asymmetric traffic .
7 Replies 7
Check my old comment to your old post'
You need pbr because pbr is only that check source of packet and forwarding it to correct ISP.
MHM
Dear MHM
I try your solution, it only affect the outbound traffic .
The Inbound is control via AS prepend
And Outbound since yoh receive defualt route from both ISP is control by pbr
And hence no asymmetric routing.
I dont have time now to share lab but my suggestion is sure work
Goodluck
MHM
Dear MHM,
If you have later on time to share small lab, it will be appreciated.
So I can understand well how it will work and test it
Thank you for your time
Hello
Why PBR?, You can control egress traffic using a local bgp weight attribute towards each ebgp peer
Kind Regards
Paul
Hello
You BGP cfg looks quite convoluted to what i understand you want to achieve , which is
Ingress from ISP perspective-
 10.0.0.0/24 via ISPA
  all other via ISPB
Egress from AS300 perspective-
prefer via ISPA for 10.0.0.0/24 users
all other local traffic via ISPB
see attached file for possible solution.
Kind Regards
Paul
hello paul,
Your config didn't match what is needed 100%
