BGP backdoor link
Dear Team,
Can u explain how does bgp backdoor link will work ,
Scenario :
Two customer sites connected  different PE
CE1>>>PE1(mpls core )PE2>>>CE2 this CE 1 and CE2 have back to back connectivity with Eigrp  , how does the loop avoidance happens here
2 Accepted Solutions
Hello.
If you are running EIGRP between CE-PE, then loop avoidance mechanism should be the SOO.
PS: read following about BGP backdoor links
http://www.cisco.com/c/en/us/support/docs/ip/border-gateway-protocol-bgp/26634-bgp-toc.html#bgpbackdoor
https://supportforums.cisco.com/document/148471/what-bgp-backdoor-feature
Hello.
If CE-PE protocol is eBGP., then ISP would be using SOO as loop-prevention mechanism.
Also, if you have same AS for both CE-PE links, then your CE would prevent the prefix to be learnt due to self AS been found in AS-path.
PS: I hope this answers your question about loop-prevention mechanism on ISP side; If you have a question about CE network, then additional information needed - what is advertised via each links, what is routing policy (active/active or active/backup), what link is primary (MPLS or backdoor) and etc.
Hello.
hi ,
i am using PE -CE as EBGP  and  both CE having backdoor link and using eigrp
Hello.
