BGP-Book
mounir.mohamed
Level 7
Level 7
Kindly advice
What is the Recommended book for BGP course (Sam-Halabi or Knet Cisco BGP)
ankurbhasin
Level 9
Level 9
Hi Mounir,
Sam-Halabi is one of the best book for BGP and you can also go through TCP/IP Vol2 by Jeff Doyle .
On side hand you can have
BGP Design and Implementation
by Randy Zhang, Micah Bartell
Ankur
Hi Mounir,
Ankur makes some good suggestions there.
However, if you are studying for the specific purpose of sitting the BGP exam, you can't go past the KnowledgeNet course notes for it, since the course is the officially recommended course for the exam.
By the way, when I sat the exam, I used the Knet course notes, Halabi and also the book advised by Ankur. The one that most closely matched the exam material was the Knet course...
Hope that helps - pls rate the post if it does.
Paresh
Thanks pkhatri i'm always found you on my way :)
sdoremus33
Level 3
Level 3
Cisco Certification by Bruce Caslow is a great resource, BGP design and implementation is good but this is way better. Also try the following link
http://www.smif101.com/Cisco%20Notes%20Page.htm
He has some really good examples that helped me. Thanks
