BGP community
att-sgcops
Please look at my configuration:
R7#sh run
Building configuration...
Current configuration:
! Last configuration change at 17:52:58 UTC Tue Apr 13 1993
! NVRAM config last updated at 17:50:34 UTC Tue Apr 13 1993
version 12.1
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname R7
class-map chris
match none
class-map COS2_TRAFFIC
match none
ip subnet-zero
no ip domain-lookup
tag-switching tdp router-id Loopback7
cns event-service server
interface Loopback0
ip address 7.x.x.x.x.255.255
interface Loopback1
ip address 6.x.x.x.x.255.255
interface Loopback2
ip address 8.x.x.x.x.255.255
interface Loopback5
no ip address
interface Loopback7
no ip address
interface Ethernet0/0
ip address 20.x.x.x.255.255.0
ip directed-broadcast
ip policy route-map vfilter
half-duplex
max-reserved-bandwidth 76
interface Serial0/0
ip address 137.x.x.x.x.255.0
traffic-shape group 101 64000 8000 8000 1000
interface Serial0/1
no ip address
shutdown
clockrate 64000
router bgp 700
redistribute connected route-map t1
neighbor 20.20.20.5 remote-as 500
neighbor 20.20.20.5 send-community
no auto-summary
ip classless
no ip http server
ip pim rp-address 10.1.23.3
access-list 1 permit 6.6.6.6
access-list 2 permit 7.7.7.7
access-list 3 permit 8.8.8.8
access-list 12 permit 30.1.1.5
access-list 33 permit any
access-list 101 deny udp any any range 16348 32767
access-list 101 permit ip any any
route-map t1 permit 10
match ip address 1
set community no-export
route-map t1 permit 20
match ip address 2
set community no-advertise
route-map t1 permit 30
match ip address 3
set community local-AS
route-map t1 permit 1000
end
I noticed some subnets not being advertised to other BGP neighbor such as 6.6.6.6, 7.7.7.7 and 8.8.8.8:
R7#sh ip bgp 7.7.7.7
BGP routing table entry for 7.7.7.7/32, version 5
Paths: (1 available, best #1, table Default-IP-Routing-Table, not advertised to any peer)
Not advertised to any peer
Local
0.0.0.0 from 0.0.0.0 (8.8.8.8)
Origin incomplete, metric 0, localpref 100, weight 32768, valid, sourced, best
Community: no-advertise
R7#sh ip bgp 8.8.8.8
BGP routing table entry for 8.8.8.8/32, version 6
Paths: (1 available, best #1, table Default-IP-Routing-Table, not advertised outside local AS)
Local
Community: local-AS
R7#sh ip bgp 6.6.6.6
BGP routing table entry for 6.6.6.6/32, version 4
Paths: (1 available, best #1, table Default-IP-Routing-Table, not advertised to EBGP peer)
Local
Community: no-export
R7#sh ip bgp 137.20.25.0
BGP routing table entry for 137.20.25.0/24, version 2
Paths: (1 available, best #1, table Default-IP-Routing-Table)
Advertised to non peer-group peers:
20.20.20.5
Local
some one tell me why?
Harold Ritter
I'm glad to see you fixed the community issue you had in your previous posting.
To answer this question, the reason these prefixes are not advertised to your eBGP neighbor is a direct effect of these special communities being attached to them.
For more information on the effect of these special communities, please refer to the following URL:
http://www.cisco.com/web/about/ac123/ac147/archived_issues/ipj_6-2/bgp_communities.html
Hope this helps,
