BGP conditional Adverisement
dangal.43
How does conditional advertisement option non-exit-map and exit-map work?
if anyone can give me the link or explanation with some good example and need in particular scenario it will be really helpful...
The document provided by Sai is nice, and here you are the step by step from the DocCD:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios124/124cg/hirp_c/ch05/brbbasic.htm#wp1111262
With Cisco IOS 12.2T or later versions, the exist-map keyword was added.
BR,
Mohammed Mahmoud.
