BGP configration
kunalgandhi
HI
can any one provide the information regarding BGP.How it work and some basic configration?
Kunal
mheusinger
Level 10
Level 10
I would recommend you to read through "Cisco IOS BGP Configuration Guide"
http://www.cisco.com/en/US/products/ps6441/products_configuration_guide_book09186a008054dd7b.html
which gives example configs for different scenarios and also explanations on the features. In addition you could read the RFC 4271, which is the current standard of BGP version 4. It is quite readable and gives "the final answer" on how BGPv4 works.
Hope this helps! Please rate all posts.
Regards, Martin
mheusinger
Level 10
Level 10
Regards, Martin
Tkanks for fast responce...
This is very good informaiton and it's realy helpful for me as I am fresher in network.
Thaks and Regards
Kunal
sean
Level 3
Level 3
I have found the cisco press book "BGP Design and Implementation" to be very helpful.
Hi Sean,
Thanks for your responce.I will reade tht.
Kunal
