BGP continuosly flapping
Ramz PV
         I'm getting below logs in my router frequently and BGP flaps. could someone tell me what are the possible causes of this issue.
Oct 2 02:33:50: %BGP-3-NOTIFICATION: received from neighbor 192.168.181.217 4/0 (hold time expired) 0 bytes
Oct 2 02:33:50: %BGP-5-ADJCHANGE: neighbor 192.168.181.217 Down Peer closed the session
Oct 2 02:33:50: %BGP_SESSION-5-ADJCHANGE: neighbor 192.168.181.217 IPv4 Unicast topology base removed from session  Peer closed the session
Oct 2 02:33:57: %BGP-5-ADJCHANGE: neighbor 192.168.181.217 Up
Oct 2 03:35:52: %BGP-3-NOTIFICATION: received from neighbor 192.168.181.217 4/0 (hold time expired) 0 bytes
Oct 2 03:35:52: %BGP-5-ADJCHANGE: neighbor 192.168.181.217 Down Peer closed the session
Oct 2 03:35:52: %BGP_SESSION-5-ADJCHANGE: neighbor 192.168.181.217 IPv4 Unicast topology base removed from session  Peer closed the session
Oct 2 03:36:03: %BGP-5-ADJCHANGE: neighbor 192.168.181.217 Up
6 Replies 6
Hello
Check your connectivity to this address as to why it's losing its peering
Res
Paul
Kind Regards
Paul
cisco_lad2004
Level 5
Level 5
As Paul suggested check your connectivity, run an extended ping between BGP peers, might be as simple as layer 1 issue. Else check that you don't have recursive lookup for peer address where by you are peering with an address you you receive via BGP peering.
/Samir
       There is no L1 issue. it is confirmed.
is the neighbor within the same subnet as your router? Or multiple hops away?
Are you using correct AS number?
Did you try to debug the BGP session?
Best regards,
Milan
Are you dropping packets when you use an extended ping between sources and destination BGP peers.
How are routes known for next hop peer address.
Of course above assumes you are peering between loopbacks, else disregard my questions.
/Samir
vishal vyas
Its look like you are getting (BGP hold time expired) messages, it means that you are missing hellos between neighbors, it could be possible when you are receiving so much traffic and it causes to BGP to miss some hellos.
Please check you interface status.
