bgp default gateway ways
Mlex1
Hello everyone i want to configure BGP to send the default route to a neighbor, i receive from ISP full veiw i can't advertise to another peer 0.0.0.0/0.
In lab on EVE, everything works perfectly by the way this step i done for 0.0.0.0/0
ip route 0.0.0.0 0.0.0.0 Null0:
as we know Null0 just for test taking 0.0.0.0/0 the default route is advertised to the intended neighbor as expected.
settings
R01
router bgp 200
bgp log-neighbor-changes
neighbor 10.10.10.2 remote-as 300
neighbor 10.10.10.2 description R03
address-family ipv4
network 0.0.0.0
neighbor 10.10.10.2 activate
neighbor 10.10.10.2 route-map RM_DEFAULT out
exit-address-family
ip prefix-list DEFAULT seq 5 permit 0.0.0.0/0
route-map RM_DEFAULT permit 10
match ip address prefix-list DEFAULT
R03
router bgp 300
network 3.3.3.3 mask 255.255.255.255
neighbor 10.10.10.1 remote-as 200
neighbor 10.10.10.1 description R1
However, in production, it’s not working, even though the configuration appears to be identical.
Wish all the best
M02@rt37
Hello @Mlex1
Try 2 method.
First on R2 delete network 0.0.0.0 command and add redistribute static command instead. Let your route-map.
Test...Check...
Other way, delete network 0.0.0.0 command on R2 and add default-information originate command instead.
In two cases, if you dont have default route on R2 RIB, you need your static default route pointing towards null0.
Best regards
21 Replies 21
M02@rt37
Hello @Mlex1
Try 2 method.
Test...Check...
Best regards
i have default in the rib, for some reason default does not advertised to the neighbor, in need just for specific neighbor not to all.
you mean like this config?
router bgp 200
neighbor 192.168.1.2 remote-as 100
neighbor 192.168.1.2 description R1
address-family ipv4
redistribute static route-map RM_DEFAULT
neighbor 10.10.10.2 default-originate
neighbor 10.10.10.2 soft-reconfiguration inbound
neighbor 192.168.1.2 activate
if yes doesn't work this way
Wish all the best
@Mlex1
you have default-route in the RIB thanks to your null0 route ? Or do you have default-route thanks to your ISP ?
Best regards
not, in production i receive full view from ISP
show ip route
B* 0.0.0.0/0 [20/0] via x.x.x.x, 1:00:00
Wish all the best
Ok so, your receive full internet table form your ISP, right ? and you want to advertise only default route to your others routers ?
Best regards
Ok so, your receive full internet table form your ISP, right ? yes
and you want to advertise only default route to your others routers ? yes but not to all my routers for specific neighbors
as show on configs upper, what i show on the picture that one not in the production
Wish all the best
Hello
As you have a default in your rib table then you only need to advertise default-information-originate to each specific neighbour, no need for static null routes and redistribution
Example:
router bgp xx
neighbour x.x.x.x default-information-originate
Kind Regards
Paul
router does not have this option
R1(config-router-af)#neighbor 10.10.10.2 default-originate
R1(config-router-af)#neighbor 10.10.10.2 default-?
default-originate
R1(config-router-af)#neighbor 10.10.10.2 default-originate ?
route-map Route-map to specify criteria to originate default
<cr> <cr>
i'm i right we need default-originate when router does't have default route? in my citution i have 0.0.0.0/0, it's possible to config or not
Wish all the best
i'm i right we need default-originate when router does't have default route?  YES !
Best regards
Hello
default-originate
its a typo on my part but as you can see you can advertise a default to a specific bgp neighbour
@Mlex1 wrote:
need default-originate when router does't have default roue? in my citution i have 0.0.0.0/0, it's possible to config or not
you can advertise a default even if you have or dont have a default in the rib of you own rtr -  but i would say if you do I would make that default information advertisement  conditional , meaning if your own rtr loses the default it will stop advertising a default to its neighbours.
This can be accomplished with a via prefix-list and route-map
example:
ip prefix-list Default_PF permit 0.0.0.0/0
route-map Default
match ip address prefix-list Default_PF
router bgp xxx
neighbor x.x.x.x default-information originate route-map Default
Kind Regards
Paul
Ok @Mlex1
Please do this on R1
router bgp 200
address-family ipv4
network 0.0.0.0
neighbor 10.10.10.2 send-community both
neighbor 10.10.10.2 route-map DEFAULT-ONLY out
route-map DEFAULT-ONLY permit 10
AS @paul driver suggest, neighbor 10.10.10.2 default-originate command should be good too. But add route-map to limit only the default-route to be advertised to that neighbor.
Best regards
network 0.0.0.0
this network advertise to all neighbor as we enable on bgp
here in my config i done your suggestion not working
both command i have
Wish all the best
@Mlex1
network 0.0.0.0
No ! -- add route-map on each neighbor ! Control what you advertise by route-map in outbound and what your receive in inbound (best practice)
Best regards
@Mlex1
Provide please these output from R1:
#sh ip route
#sh ip bgp neigh 10.10.10.2 advertised-routes
Best regards
