bgp default gateway ways
Mlex1
Hello everyone i want to configure BGP to send the default route to a neighbor, i receive from ISP full veiw i can't advertise to another peer 0.0.0.0/0.
In lab on EVE, everything works perfectly by the way this step i done for 0.0.0.0/0
ip route 0.0.0.0 0.0.0.0 Null0:
as we know Null0 just for test taking 0.0.0.0/0 the default route is advertised to the intended neighbor as expected.
settings
R01
router bgp 200
bgp log-neighbor-changes
neighbor 10.10.10.2 remote-as 300
neighbor 10.10.10.2 description R03
address-family ipv4
network 0.0.0.0
neighbor 10.10.10.2 activate
neighbor 10.10.10.2 route-map RM_DEFAULT out
exit-address-family
ip prefix-list DEFAULT seq 5 permit 0.0.0.0/0
route-map RM_DEFAULT permit 10
match ip address prefix-list DEFAULT
R03
router bgp 300
network 3.3.3.3 mask 255.255.255.255
neighbor 10.10.10.1 remote-as 200
neighbor 10.10.10.1 description R1
However, in production, it’s not working, even though the configuration appears to be identical.
Wish all the best
21 Replies 21
Harold Ritter
Hi @Mlex1 ,
You do not need to locally generate the default route as you already have it in BGP coming from the ISP. The easiest would be to just propagate this default route to the internal peer. You would set a route-map towards this internal peer denying everything but the default route.
route-map default-only permit 10
match ip address prefix-list default-only
route-map default-only deny 20
ip prefix-lits default-only permit 0.0.0.0/0
router bgp xxx
neighbor <internal peer IP address> route-map default-only out
route-map default-only deny 20 by default this step working ? no
other steps same as  my config
Hello Harold Ritter
currently my config on routers
router bgp 200
neighbor 192.168.1.2 remote-as 100
neighbor 192.168.1.2 description R1
address-family ipv4
neighbor 10.10.10.2 activate neighbor
10.10.10.2 send-community both
neighbor 10.10.10.2 soft-reconfiguration inbound
neighbor 192.168.1.2 activate
exit-address-family
router bgp 100
neighbor 192.168.1.1 remote-as 200
neighbor 192.168.1.1 default-originate
Wish all the best
Hi @Mlex1 ,
Sorry I overlooked your route-map configuration.
My point is that you do not need to configure the network statement to originate the default route locally, as it already received fro m the ISP.
if you mean default from R2 advertise to R1 this step i emulate just for 0.0.0.0/0 in production i receive full veiw from ISP
and my config looks right?
Wish all the best
Hi @Mlex1 ,
Yes, I understand that R2 emulates the ISP in your test topology and that in your production network you receive the full internet routing table + the default route.
You config looks good. The route-map propagates the default route to the internal peer and denies everything else.
as i see don't work my configs i don't know why anyway need troubleshooting on eve i tried everything looks good
Wish all the best
Hi @Mlex1 ,
Do you mean that it doesn't work in your lab topology or in production?
As I mentioned, if you receive the default from the ISP, propagating it to the internal peer should be fairly easy.
