BGP default route route-map
Krasnoperov
Please advise
I have BGP peer with upstaream ISP
I need recieve default route only
I want to do this via route-map with prefix-list (not just perfix-list)
How can I do this?
Now I do next (but it doesn't work)
router bgp 5xxxx
bgp log-neighbor-changes
bgp deterministic-med
neighbor 193.xxx.zzz.xx remote-as 900
neighbor 193.xxx.zzz.xx description ISP UpStream
neighbor 193.xxx.zzz.xx version 4
address-family ipv4
  network 193.0.0.0 mask 255.255.252.0
  neighbor 193.xxx.zzz.xx activate
  neighbor 193.xxx.zzz.xx soft-reconfiguration inbound
  neighbor 193.xxx.zzz.xx route-map map-900-ISP-in in
  neighbor 193.xxx.zzz.xx route-map map-900-ISP-out out
sh route-map map-900-ISP-in
route-map map-900-ISP-in, permit, sequence 30
  Match clauses:
    ip address prefix-lists: def_only
  Set clauses:
  Policy routing matches: 0 packets, 0 bytes
route-map map-900-ISP-in, permit, sequence 40
  Match clauses:
  Set clauses:
    local-preference 90
sh ip prefix-list def_only
ip prefix-list def_only: 2 entries
   seq 15 deny 0.0.0.0/0 ge 1
   seq 20 permit 0.0.0.0/0
2 Accepted Solutions
Best option will be to ask your ISP to give you only default route.
Apart from that, I have found that as-path access-list are very handy for such situation. Just permit ^$ in AS-PATH access-list and you are done.
However, as per your requirement ( assuming your ISP do give you default route).
ip prefix-list DEFAULT permit 0.0.0.0/0
route-map MATCH_DEFAULT
match ip address prefix DEFAULT
router bgp AS_NUMBER
neighbour X.X.X.X route-map MATCH_DEFAULT in
above mention commands, will do the trick
PS: The rest of the routes will still be in BGP stable, however routing table will install only default learning via BGP in its routing table.
Smitesh
PS: Please rate helpful posts.
get rid of the permit 30 statement in your inbound route-map
Regards.
Alain
26 Replies 26
Smitesh
I tried this, unfortunatly I stil receive all routes that provider push me
In routing table or in BGP table ??
Meanwhile, I will just lab it to confirm the same.
Smitesh
both
Ahhh...
Please remove seq 15 from your prefix-list and check
Don't forget to soft clear bgp after you modify you configs.
Smitesh
do this : clear ip bgp * in and it will work
Regards.
Alain
is that ok if do
neigbour x.x.x.x shut
no neigbour x.x.x.x shut
same result
Yes, it will result same, however with taking your bgp peer down.
If you are logging into router from some remote location and if you only have one ISP link, you will lose the connectivity to router as soon as neig X.X.X.X shut command is issued.
In my opinion best will be to do
clear ip bgp * soft in
Smitesh
no just do a soft clear like i proposed.
Regards.
Alain
I can't do that to *
Is that ok
clear ip bgp 193.xxx.zzz.xx soft in
same result
I guess, Cadet had typo error.
Yup you can do the command which you have suggested; however as informed by you in one of the thred that you shut/no-shutted bgp peer; but still the same status.
Then, even if you soft clear the bgp peer will not get you any better results.
But again there  is not harm in doing the same.
Smitesh
I just did a quick lab, and as I suggested earlier, it works !!!
I made simple topology as R1--------------R2.
Please see config below and show command outputs:
R1
int lo0
ip add 1.1.1.1 255.255.255.0
int lo1
ip add 11.11.11.11 255.255.255.0
int fa0/0
ip add 192.168.1.1 255.255.255.0
no shut
router bgp 100
net 1.1.1.0 mask 255.255.255.0
net 11.11.11.0 mask 255.255.255.0
net 0.0.0.0 mask 0.0.0.0
nei 192.168.1.2 remote 200
exit
ip route 0.0.0.0 0.0.0.0 Null0
end
R2
int lo0
ip add 2.2.2.2 255.255.255.0
int lo1
ip add 22.22.22.22 255.255.255.0
int fa0/0
ip add 192.168.1.2 255.255.255.0
no shut
router bgp 200
net 2.2.2.0 mask 255.255.255.0
net 22.22.22.0 mask 255.255.255.0
nei 192.168.1.1 remote 100
nei 192.168.1.1 route-map DEF in
ip prefix DEF permit 0.0.0.0/0
route-map DEF
match ip add prefix DEF
exit
end
R2#sh ip bgp regexp ^[^$]
BGP table version is 4, local router ID is 22.22.22.22
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
              r RIB-failure, S Stale
Origin codes: i - IGP, e - EGP, ? - incomplete
   Network          Next Hop            Metric LocPrf Weight Path
*> 0.0.0.0          192.168.1.1              0             0 100 i
R2#sh ip bgp summ
BGP router identifier 22.22.22.22, local AS number 200
BGP table version is 4, main routing table version 4
3 network entries using 360 bytes of memory
3 path entries using 156 bytes of memory
3/2 BGP path/bestpath attribute entries using 372 bytes of memory
1 BGP AS-PATH entries using 24 bytes of memory
0 BGP route-map cache entries using 0 bytes of memory
0 BGP filter-list cache entries using 0 bytes of memory
Bitfield cache entries: current 1 (at peak 1) using 32 bytes of memory
BGP using 944 total bytes of memory
BGP activity 3/0 prefixes, 3/0 paths, scan interval 60 secs
Neighbor        V    AS MsgRcvd MsgSent   TblVer  InQ OutQ Up/Down  State/PfxRcd
192.168.1.1     4   100       9       9        4    0    0 00:05:33        1
R2#
R2#sh ip route bgp
B*   0.0.0.0/0 [20/0] via 192.168.1.1, 00:05:15
R2#
Smitesh
router bgp 5xxxx
address-family ipv4
  network 193.xxx.zzz.00 mask 255.255.252.0
route-map map-900-ISP-in, deny, sequence 10
  Match clauses:
    as-path (as-path filter): 1
  Set clauses:
  Match clauses:
  Set clauses:
  Match clauses:
  Set clauses:
    local-preference 90
sh ip as-path-access-list 1
AS path access list 1
    permit _6451[2-9]_
    permit _645[2-9][0-9]_
    permit _64[6-9][0-9][0-9]_
    permit _65[0-9][0-9][0-9]_
ip prefix-list def_only: 1 entries
sh ip route bgp
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
       + - replicated route, % - next hop override
Gateway of last resort is x.x.x.x to network 0.0.0.0
B*    0.0.0.0/0 [20/0] via x.x.x.x, 01:38:58
B     193.xxx.zzz.00/22 [20/0] via 193.xxx.zzz.xx, 00:34:01
sh ip bgp
BGP table version is 62, local router ID is
              r RIB-failure, S Stale, m multipath, b backup-path, x best-external, f RT-Filter
*  0.0.0.0          193.xxx.zzz.xx                         0 888 i
*>                  x.x.x.x                       200      0 777 i
*> 193.xxx.zzz.00/22 193.xxx.zzz.xx           0     90      0 900 i
I do neighbor 193.xxx.zzz.xx  shut
and no neighbor 193.xxx.zzz.xx  shut
still have route
Not too sure why you are still receiving other routes apart from default.
Any chance, if you can reload the router and check if issue persists.
Apart from reload, you can also try using only prefix-list in route-map as suggested in my sample configs.
Smitesh
