BGP ,EIGRP route tuning .
maahiraahi
Hi friends,
<br /><br />Could any one guide me for configuring the devices shown in the dia.
<br /><br />I need to configure the following things
<br /><br />
<br /><br />1.Need to run EIGRP between all the 4 devices,
<br /><br />2.Need to publish 50 & 51 segments on Router R1
<br /><br />3. Need ot publish 52,23,&54 segments on router R2
<br /><br />if Telco 1 fails all the segments should publish on Router R2,
<br /><br />IF Teclo 2 fails all the segments should publish on router R1
<br />
<br />current configuration:
<br />configured bgp with telco1 & 2,its working fine.
<br />eigrp running, but unable to form neighbourship with router 1 and router 2 .
<br />configured default static route on switches (0.0.0.0 0.0.0.0 1.1.1.1 on switch 1 and 0.0.0.0 0.0.0.0 1.1.2.1 on switch 2)
<br />configured route-map with prefix list for allowing above said segment route advatisement to the respective telcos ( used as-perpend ).
<br />M
<br /><br />
<br /><br />Thanks in advance
<br /><br />
<br /><br />rm
<br /><br />
<br /><br />
<br /><br />1) Diagram.JPG - Diagram.bmp
<br /><br />
12 Replies 12
Giuseppe Larosa
Hello Raahi,
first of all you need to be able to have EIGRP neighborships between R1,R2 and SW1,SW2.
to build a successful neighborship you need:
to use the same EIGRP AS number 123 on all devices.
to have a network command that includes the ip subnet used on link R1,SW1 and R2,Sw2 on both sides.
you can check this with
sh ip eigrp interfaces
sh ip eigrp neighbors
for the BGP part:
MED cannot pass via a third party provider the same happens for local preference.
you can use selective AS path prepending on R1 and R2 to make R1 more attractive for segments 50,51 and R2 more attractive for segments 52,53
redundancy is provided by the protocol
router on left side need to have an iBGP session to compare the routes they receive via the two different providers.
Some tuning on left site may be needed later for example using local preference to enforce the desired routing policies.
Hope to help
Giuseppe
Hello Rahi.
Is the link between the Switches S1 and S2 layer 3 or layer 2? Hope its a layer 3 as you said u have to enable EIGRP over all the 4 Devices(R1,R2.S1 and S2)..In that scenario ,how EIGRP neighbor ship will form between R1 and R2?
please get me the segments network address to be published on R1 and R2
regards
Rahul
few quires.
first we will finish eigrp.
i am Unable to build eigrp relationship between two routers as these ipaddress is in diffrent segments.
can i conntect two routers with cable and assign /30 ip , and add in eigrp network command ?
or changing any one router ip address will do ?
configuration of eigrp on all the 4 devices is as below,
router eigrp 101
redistribute connected
redistribute static
redistribute bgp 123
network 1.0.0.0
default-metric 2000 10000 255 1 1500
no auto-summary
no eigrp log-neighbor-changes
yes...the neighborship will be formed
To build EIGRP neighbor ship the neighbors should be directly connected and should be in the same network.
I have a few queries
1.Should EIGRP enabled on all devices (R1,R2,S1 and S2)
2.Have you configured iBGP between R1 and R2
Please share the network address to be published to external network
Rahul
eigrp enable on all the devices.
ibgp is configured between 2 routers also.
regards
rm
Hi friend,
Then R forms EIGRP neigborship with S1,S1 forms neighborship with R1 and S2,S2 froms neighborship with R2 and S1 and R2 forms neighborship with only S2 as R1 and R2 are not directly connected.(assume that Routed Port has been configured for Router to Swicth and Switch to Switch connectivity)
To get more clarification ,kindly share the configuration of all devices, if possible\
Rahul
eigrp conf on routers,
router eigrp 101
redistribute static
network 1.0.0.0
no auto-summary
Eigrp conf on switches,
S2:
router eigrp 101
redistribute static
network 1.0.0.0
no auto-summary
ip route 0.0.0.0 0.0.0.0 1.1.2.1
S1:
router eigrp 101
redistribute static
network 1.0.0.0
no auto-summary
ip route 0.0.0.0 0.0.0.0 1.1.1.1
Hi ,
Required all the configuration ,not only EIGRP Config
regards
Rahul
configuration as below,
Router 2:
router eigrp 101
redistribute static
network 1.0.0.0
no auto-summary
router bgp 123
bgp log-neighbor-changes
neighbor x.x.x.x remote-as 123
neighbor x.x.x.x remote-as xxxx- telco2 as
neighbor x.x.x.x ebgp-multihop 5
neighbor x.x.x.x update-source Loopback2
address-family ipv4
redistribute static
neighbor 1.1.1.1 activate
neighbor 1.1.1.1 next-hop-self
neighbor x.x.x.x activate
neighbor x.x.x.x soft-reconfiguration inbound
neighbor x.x.x.x route-map telco2_out out
no auto-summary
no synchronization
network 1.1.1.0 mask 255.255.255.0
network 1.1.2.0 mask 255.255.255.0
network 1.1.50.0 mask 255.255.255.0
network 1.1.51.0 mask 255.255.255.0
network 1.1.52.0 mask 255.255.255.0
network 1.1.53.0 mask 255.255.255.0
network 1.1.54.0 mask 255.255.255.0
aggregate-address 1.1.0.0 255.255.0.0
ip prefix-list r2_traffic seq 1 permit 1.1.2.0/24
ip prefix-list r2_traffic seq 2 permit 1.1.50.0/24
ip prefix-list r2_traffic seq 3 permit 1.1.51.0/24
ip prefix-list r2_traffic seq 4 permit 1.1.52.0/24
ip prefix-list r1_traffic seq 1 permit 1.1.1.0/24
ip prefix-list r1_traffic seq 2 permit 1.1.53.0/24
ip prefix-list r1_traffic seq 3 permit 1.1.54.0/24
route-map telco2_out permit 10
match ip address prefix-list r1_traffic
set as-path prepend 123 123
route-map telco2_out permit 20
match ip address prefix-list r2_traffic
Router 1:
router eigrp 101
redistribute static
network 1.0.0.0
no auto-summary
router bgp 123
neighbor x.x.x.x remote-as xxxx- telco1 as
address-family ipv4
redistribute static
neighbor 1.1.2.1 activate
neighbor 1.1.2.1 next-hop-self
neighbor x.x.x.x route-map telco1_out out
no auto-summary
synchronization
route-map telco1_out permit 10
route-map telco1_out permit 20
S2:
router eigrp 101
redistribute static
network 1.0.0.0
no auto-summary
S1:
router eigrp 101
redistribute static
network 1.0.0.0
no auto-summary
Hi ..
Is the link between the Router and Switch Layer 3 or Layer 2?
Is the link between the the Switches Layer 3 or Layer 2?
meanwhile I will go through configuration and let you know the changes has to be done..
Rahul
Dear Rahul ,
Switches are L3 & connected by cable. not l3 link.
The problem i facing is
1.unable to form eigrp relation ship with routers. rechability is done through static route on both the swithces.(now both eigrp and static is running)
2. on router 2 external routes from our organization network are unable to add in routing table(think due to aggregate command & finding RIB errors on received routes). best route to external network (in side the organization)is through router1 execpt for the locations connected only through TELCO2.
Kindly guide me.
rm
Hi Rm,
Please go through the below config
R1
Router Eigrp 101
Network 1.0.0.0
Router bgp 123
neighbor remote-as 250 ###As per the digram (eBGP)
neighbor [External_peer] soft-reconfiguration inbound
neighbor prefix-list Defrt in ##Accept default Route only)
neighbor [External_peer] route-map Telco_1 out ##AS_Path prepend
neighbor [External_peer] update-source [loopback 2]
neighbor [External_peer] ebgp-multihop 5
neighbor [internal_peer] remote-as 121 ###iBGP with R2
neighbor [internal_peer] next-hop-self
network 1.1.53.0 mask 255.255.254.0
ip prefix-list r1_traffic seq 2 permit 1.1.53.0/23
Ip prefix-list Defrt seq 5 permit 0.0.0.0/0
R2
Router Eigrp 101
Network 1.0.0.0
Router bgp 123
neighbor remote-as 300 ###As per the digram (eBGP)
neighbor [External_peer] route-map Telco_2 out ##AS_Path prepend
S1
router eigrp 101
network 1.0.0.0
network 2.0.0.0
redistribute static meric [BW] [Delay] [reliabilty] [load] [MTU]
exit
ip route x.x.x.x mask x.x.x.x For internal network (2.0,1.0,53.0...)
s2
router eigrp 101
network 1.0.0.0
network 2.0.0.0
exit
To get a lear picture please share the diagram with all Interface IP address, including loop back...
And also share me the following output
1.Show ip bg summary
2.sh ip bgp
3.show ip bgp neighbors
Rahul
Rahul
