BGP Error
promise2k
i wanted to perform a swap of my BGP router i.e from ASR-1001 to ASR-1001-X. since this is a swap all configuration remained the same, nothing changed. when i plugged in the new router by e-BGP was not coming up. i was getting the below error message
BGP-4-MSGDUMP: unsupported or mal-formatted message received from x.x.x.x:
FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0055 0104 3DBA 00B4 0A2C 110F 3802 0601
0400 0100 0102 0280 0002 0202 0002 0641 0400 003D BA02 0840 0600 7800 0101 0002
1405 1200 0100 0100 0200 0100 0200 0200 0100 8000 02
below is the BGP config which i have
router bgp zzzzz
 bgp router-id 10.254.3.1
 bgp always-compare-med
 bgp log-neighbor-changes
 bgp deterministic-med
 neighbor 10.254.3.2 remote-as zzzzz
 neighbor 10.254.3.2 update-source Loopback0
 neighbor x.x.x.x remote-as 15802
 neighbor x.x.x.x dont-capability-negotiate
 address-family ipv4
  bgp dampening
  network y.y.y.y mask 255.255.255.0
  network y.y.x.x mask 255.255.252.0
  neighbor 10.254.3.2 activate
  neighbor 10.254.3.2 next-hop-self
  neighbor x.x.x.x activate
  neighbor x.x.x.x soft-reconfiguration inbound
  neighbor x.x.x.x route-map LOCAL-PREF in
  neighbor x.x.x.x route-map PREPEND out
 exit-address-family
the other party is a bit difficult to deal with, so if i can do anything to resolve this issue on my end it would be great if i can get pointers.
Hi @promise2k ,
You should definitely upgrade to a version that incorporates the fix for CSCva92216. This should fix the issue.
21 Replies 21
neighbor X.X.X.X dont-capability-negotiate
<<- disable capability nego """if""" you dont use it
yes indeed, in the original configuration this  command was not there, but after some googling i saw others saying that command might help with the error but surely it ddnt, so i will remove that command once i get a working solution.
show ip bgp neighbors
share this
the three capability are
and from my experience the second can most one that generate the error message,
so can you confirm what other peer use ?
  • Route Refresh Capability
  • 4-byte AS Capability
  • Multi-Protocol Capability
Please see below output of
show ip bgp nei
specific for this neighbor thats giving me a problem.
BGP neighbor is x.x.x.x,  remote AS 15802, external link
  BGP version 4, remote router ID 10.44.17.15
  BGP state = Established, up for 2d01h
  Last read 00:00:05, last write 00:00:44, hold time is 180, keepalive interval is 60 seconds
  Neighbor sessions:
    1 active, is not multisession capable (disabled)
  Neighbor capabilities:
    Route refresh: advertised and received(new)
    Four-octets ASN Capability: advertised and received
    Address family IPv4 Unicast: advertised and received
    Graceful Restart Capability: received
      Remote Restart timer is 120 seconds
      Address families advertised by peer:
        IPv4 Unicast (was not preserved
    Enhanced Refresh Capability: advertised
    Multisession Capability:
    Stateful switchover support enabled: NO for session 1
  Message statistics:
    InQ depth is 0
    OutQ depth is 0
                         Sent       Rcvd
    Opens:                  1          1
    Notifications:          0          0
    Updates:                3     688762
    Keepalives:          3274          3
    Route Refresh:          0          0
    Total:               3278     688766
  Default minimum time between advertisement runs is 30 seconds
 For address family: IPv4 Unicast
  Session: x.x.x.x
  BGP table version 10353, neighbor version 10353/0
  Output queue size : 0
  Index 7, Advertise bit 1
  7 update-group member
  Inbound soft reconfiguration allowed
  Inbound path policy configured
  Outbound path policy configured
  Route map for incoming advertisements is LOCAL-PREF
  Route map for outgoing advertisements is PREPEND
  Slow-peer detection is disabled
  Slow-peer split-update-group dynamic is disabled
                                 Sent       Rcvd
  Prefix activity:               ----       ----
    Prefixes Current:               2        462 (Consumes 111053400 bytes)
    Prefixes Total:                 2       1146
    Implicit Withdraw:              0        684
    Explicit Withdraw:              0          0
    Used as bestpath:             n/a        462
    Used as multipath:            n/a          0
    Saved (soft-reconfig):        n/a     924983 (Consumes 110997960 bytes)
                                   Outbound    Inbound
  Local Policy Denied Prefixes:    --------    -------
    route-map:                            0    2769348
    Other Policies:                    1096        n/a
    Total:                             1096    2769348
  Number of NLRIs in the update sent: max 1, min 0
  Last detected as dynamic slow peer: never
  Dynamic slow peer recovered: never
  Refresh Epoch: 1
  Last Sent Refresh Start-of-rib: never
  Last Sent Refresh End-of-rib: never
  Last Received Refresh Start-of-rib: never
  Last Received Refresh End-of-rib: never
      Sent   Rcvd
Refresh activity:       ----   ----
  Refresh Start-of-RIB          0          0
  Refresh End-of-RIB            0          0
  Address tracking is enabled, the RIB does have a route to x.x.x.x
  Connections established 5; dropped 4
  Last reset 2d02h, due to Admin. shutdown of session 1
  Transport(tcp) path-mtu-discovery is enabled
  Graceful-Restart is disabled
Connection state is ESTAB, I/O status: 1, unread input bytes: 0
Connection is ECN Disabled, Mininum incoming TTL 0, Outgoing TTL 1
Local host: y.y.y.y, Local port: 25051
Foreign host: x.x.x.x, Foreign port: 179
Connection tableid (VRF): 0
Maximum output segment queue size: 50
Enqueued packets for retransmit: 0, input: 0  mis-ordered: 0 (0 bytes)
Event Timers (current time is 0xB39DEDB1):
Timer          Starts    Wakeups            Next
Retrans          3277          2             0x0
TimeWait            0          0             0x0
AckHold         45176       5814             0x0
SendWnd             0          0             0x0
KeepAlive           0          0             0x0
GiveUp              0          0             0x0
PmtuAger       176781     176780      0xB39DF0D0
DeadWait            0          0             0x0
Linger              0          0             0x0
ProcessQ            0          0             0x0
iss:  714318287  snduna:  714380682  sndnxt:  714380682
irs: 4182768689  rcvnxt: 4269504011
sndwnd:  32407  scale:      0  maxrcvwnd:  16384
rcvwnd:  15503  scale:      0  delrcvwnd:    881
SRTT: 1000 ms, RTTO: 1003 ms, RTV: 3 ms, KRTT: 0 ms
minRTT: 2 ms, maxRTT: 1000 ms, ACK hold: 200 ms
Status Flags: active open
Option Flags: nagle, path mtu capable
IP Precedence value : 6
Datagrams (max data segment is 1460 bytes):
Rcvd: 65613 (out of order: 0), with data: 62367, total data bytes: 86735321
Sent: 82827 (retransmit: 2, fastretransmit: 0, partialack: 0, Second Congestion: 0), with data: 3276, total data bytes: 62394
 Packets received in fast path: 0, fast processed: 0, slow path: 0
 fast lock acquisition failures: 0, slow path: 0
TCP Semaphore      0x7EFEC5BD2A68  FREE
so there are two capability unsupport in one of Peer
we will start with disable enhanced-refresh capability in your side,
neighbor x.x.x.x dont−capability−negotiate enhanced−refresh
please check the capability after apply command
is i use this command
does this not disable all negotiations including the enhanced-refresh?
Yes, but I think you not re-establish the BGP between two peers, am I right?
Hi @promise2k ,
Yes, this command will remove all capability negotiation from the outgoing BGP open message. The issue is that the other side still sends the BGP open message with capability negotiation and IOS-XE doesn't understand the capability parameters, most probably due to CSCva92216.
hi there
i tried the below steps/commands but unfortunalty my issue wasnt solved.
1. i tried this command
but it ddnt help.
2. i also tried the command
 it ddnt help
3. i wanted to try this command but its not suppoted on my IOS
neighbor x.x.x.x dont−capability−negotiate four−byte−as
4. just for the fun of it i also tried this command but also not supposed
5. as i was just googling i saw someone else faced this issue and addressed it by enabling IPv6 but it ddnt work for me.
router bgp xxxxx
address-family ipv6
Right now my router is on IOS XE 16.0.3 i am thinking if upgrading this. would this make a diffrence. if it does, what is the recocomended version that i should upgrade to?
only try this command before upgrade
neighbor
 <only one neighbor which is x.x.x.x>
ip-address ha-mode graceful-restart
then check the
check if it now advertise and received.
i tried this command but unfortunately it ddnt work. i had to upgrade the IOS from IOS XE 16.03.05 to 17.01.01. that solved my issue. thank again for all your help.
Hi @promise2k ,
Harold Ritter
Hi @promise2k ,
What version of code are you running on the new device? You might be hitting this bug:
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCva92216
