BGP flapping
nany96901
Dear Team
my router gateway is my BGP neighbor
without the BGP configured, im able to ping my gateway with no loss of ICMP .
if BGP is configured, then if i ping to my gateway, i get packet loss.
BGP drops when packet drop.
eBGP peering establishes, then drops, re-establishes , then drops for every 20 - 30 seconds
what would be the issue, please suggest
below are the configuration details
interface GigabitEthernet0/0/0
 description ************GOOGLE INPUT***********
 ip address 1.1.1.1 255.255.255.252
 ip flow egress
 load-interval 30
 negotiation auto
router bgp XXXX
 no bgp default ipv4-unicast
 no bgp enforce-first-as
 bgp log-neighbor-changes
 bgp bestpath as-path multipath-relax
 neighbor 1.1.1.2 remote-as YYYY
 neighbor 1.1.1.2 password 7 *************************************
address-family ipv4
  no synchronization
neighbor 1.1.1.2 activate
no auto-summary
 exit-address-family
IND-INT#show interfaces gigabitEthernet 0/0/0
GigabitEthernet0/0/0 is up, line protocol is up
  Hardware is 4XGE-BUILT-IN, address is xxxxxxxxx (bia xxxxxxxxx)
  Description: ************GOOGLE INPUT***********
  Internet address is 1.1.1.1/30
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
     reliability 255/255, txload 1/255, rxload 2/255
  Keepalive not supported
  Full Duplex, 1000Mbps, link type is auto, media type is LX
  output flow-control is off, input flow-control is off
  Last input 00:00:02, output 00:00:46, output hang never
  Input queue: 0/375/0/0 (size/max/drops/flushes); Total output drops: 12830
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  30 second input rate 9880000 bits/sec, 1040 packets/sec
  30 second output rate 6970000 bits/sec, 4451 packets/sec
     17080544846 packets input, 22698441757070 bytes, 0 no buffer
     Received 1393 broadcasts (0 IP multicasts)
     0 watchdog, 253977 multicast, 0 pause input
     11445196608 packets output, 1842515648152 bytes, 0 underruns
     0 output errors, 0 collisions, 2 interface resets
     0 lost carrier, 0 no carrier, 0 pause output
Narayan
Two things:
1. What the HW model you ar using ? is there any kind of high CPU after enabling BGP ? any kind of memory buffer logs ??
2. share the output of "sh log" and "sh ip route <GW-IP>" for 20-30 sec. when BGP is up and you are able to ping your GW with packet loss.
Vivek
