BGP flowspec SNMP counters
SalimG
Does anyone know if IOSXR on ASR9K supports SNMP counters for BGP flowspec announces ?
All I want to do is to retrieve the counters using SNMP.
cf:
RP/0/RSP0/CPU0:XXX#show flowspec afi-all detail
Wed Mar 6 10:55:53.481 CET
AFI: IPv4
Flow :Dest:X.X.X.X/32,Proto:=17
Actions :Traffic-rate: 0 bps (bgp.1)
Statistics (packets/bytes)
Matched : 3650/1311959
Dropped : 3650/1311959
I'm trying to retrieve the 3650/1311959 values.
I looked in the BGP4-MIB and was not able to find any relevant counter.
Any hint is welcome.
Thanks.
Salim
Nicolas Fevrier
Hi Salim,
no SNMP counters.
Only CLI outputs and NC/XML.
Kind regards,
N.
Nicolas Fevrier
Hi Salim,
no SNMP counters.
Kind regards,
N.
Thanks Nicolas.
