BGP issue
olly ahmed
I am getting an issue that is a router has so many entries in bgp table but bgp route is blank. Can anyone specify how it is possible and how to configure it, so that no routes from bgp in routing table. Below is the situation.
A>show ip protocols
*** IP Routing is NSF aware ***
Routing Protocol is "bgp 65535"
  Outgoing update filter list for all interfaces is 100
  Incoming update filter list for all interfaces is not set
  Mapping external information into routing table via 'BGP-IPV4-RIB-FILTER'
  Route flap dampening configured and enabled
  Halflife time 10 minutes, reuse value 1500
  Suppress value 2000, maximum suppress time 15
  IGP synchronization is disabled
  Automatic route summarization is disabled
  Neighbor(s):
    Address          FiltIn FiltOut DistIn DistOut Weight RouteMap
    x.x.x.x                              100        SET-NEXTHOP
  Maximum path: 1
  Routing Information Sources:
    Gateway         Distance      Last Update
    x.x.x.x                         20      1y45w
    x.x.x.x                         20      1y45w
    x.x.x.x                         20      1y45w
    x.x.x.x                         20      1y45w
  Distance: external 20 internal 200 local 200
A>show ip route bgp
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route, H - NHRP
       + - replicated route, % - next hop override
Gateway of last resort is x.x.x.x to network 0.0.0.0
A>
route-views.optus.net.au>show ip bgp
BGP table version is 403392628, local router ID is x.x.x.x
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
              r RIB-failure, S Stale, m multipath, b backup-path, x best-external
Origin codes: i - IGP, e - EGP, ? - incomplete
   Network          Next Hop            Metric LocPrf Weight Path
*  1.0.4.0/24       x.x.x.x                         0 7474 1221 38803 56203 i
*                            x.x.x.x            20             0 7474 1221 38803 56203 i
Try to check "show ip bgp 1.0.4.0/24" and "show runn | sec bgp"
