BGP Load Balancing Scenario
Simon Young
I am looking for some guidance with the following. I have a feeling I am missing something or that there is a better way
I have the following setup, eBGP to the same ISP, iBGP inside the AS between the routers and 6509s
I would like to do the following, lets say I have 1.1.1.0.... 1.1.6.0
These are advertised by my 6509s through BGP. I would like to balance the traffic across both of the links, so inbound/outbound traffic would be
1.1.1.0 to 3925 (primary) and 3825 as secondary
1.1.2.0 to 3825 (primary) and 3925 as secondary
I was thinking I should be able to do this using route maps
on the 3925
access-list 1 permit 1.1.1.0
access-list 1 permit 1.1.3.0
access-list 1 permit 1.1.5.0
access-list 2 permit 1.1.2.0
access-list 2 permit 1.1.4.0
access-list 2 permit 1.1.6.0
route-map subnet permit 10
match ip address 1
set as-path prepend 65401 65401
route-map subnet permit 20
match ip address 2
router bgp x.x.x.x
neighbor <core1> route-map subnet in
neighbor <core2> route-map subnet in
3825
match ip address 2
match ip address 1
router bgp x.x.x.x
Any help would be much appreciated
Giuseppe Larosa
Hello Simon,
if you are doing eBGP to the same AS ISP you can use MED outbound to influence how traffic is routed to your network and so setting a lower or higher metric is enough.
In any case the route-map should be applied outbound to the eBGP neighbor and not inbound to the iBGP sessions.
This is the usual practice.
route-map toISP-NA permit 10
match ip address 1
set metric 1000
route-map toISP-NA permit 20
match ip address 2
set metric 500
router bgp x.x.x.x
neigh route-map toISP-NA out
on second border router
route-map toISP-NB permit 10
match ip address 1
set metric 500
route-map toISP-NB permit 20
match ip address 2
set metric 1000
router bgp x.x.x.x
neigh route-map toISP-NB out
Hope to help
Giuseppe
Giuseppe Larosa
Hello Simon,
match ip address 1
set metric 1000
match ip address 2
set metric 500
router bgp x.x.x.x
match ip address 1
set metric 500
match ip address 2
set metric 1000
router bgp x.x.x.x
Hope to help
Giuseppe
