BGP Load Balancing
retsek1984
I have 3 ISP's and I am advertising my IP blocks to all of them. I would like to find out how I can influence outbound traffic to go out the same way its coming back in i.e If I have 192.168.1.0/24 being advertised to ISP X , I would like it to go out thru ISP X...
7 Replies 7
Bryan Lee
Hi Kester,
Do you have your own AS? is it routed with your all other ISPs?
Hi Anil,
I have my own AS number..and it is indeed routed on all ISP's
Hi Kester ,
                If you want to influence outgoing traffic via particular ISP .X this change can be achieved only via Static route with high weightage to rest of two ISP Y,X .
                Else if you dont want static route you can have weightage attributes configured towards your neigbor ISP.X ,Y,Z ,which will have influence to your outgoing traffic
router bgp 65300
network 192.168.1.0 mask 255.255.255.0
neighbor 10.10.10.1 remote-as 65311
neighbor 10.10.10.1 weight 100
neighbor 10.20.20.1 remote-as 65312
neighbor 20.20.20.1 weight 200
neighbor 10.30.20.1 remote-as 65313
neighbor 20.20.20.1 weight 300
no auto-summary
San
HTH Regards Santhosh Saravanan
Hi SANTHOSHKUMAR,
Thank you for the response. However my idea was if I have the following setup
My IP Blocks 192.168.1.0 being advertised to ISP X
192.168.2.0 being advertised to ISP Y
192.168.3.0 being advertised to ISP Z
For outbound traffic I would like a setup in which
192.168.1.0 goes out and comes back through ISP X
192.168.2.0 goes out and comes back through ISP Y
192.168.3.0 goes out and comes back through ISP Z
Idea I am trying to configure is a block being advertised to a particular ISP should be the same it goes out as explained above.
Hi kester ,
             yeah this can be achieved by using route-map on your interface configuration
ip access-list extended ISP1
permit   ip 192.168.10.0 0.0.0.255 any
ip access-list extended ISP2
permit   ip 192.168.20.0 0.0.0.255 any
ip access-list extended ISP3
permit   ip 192.168.30.0 0.0.0.255 any
route-map traffic permit 10
match ip address ISP1
set ip next-hop x.x.x.x
route-map traffic permit 20
match ip address ISP2
set ip next-hop y.y.y.y
route-map traffic permit 30
match ip address ISP3
set ip next-hop Z.Z.Z.Z
If your router interface carries these all 3 network traffic on fastethernet 0/1
interface fastethernet 0/1
ip policy route-map traffic
else if you each network segment defined on separete physical interface on router
route-map traffic1 permit 10
route-map traffic2 permit 10
route-map traffic3 permit 10
ip policy route-map traffic1
interface fastethernet 0/2
ip policy route-map traffic2
interface fastethernet 0/3
ip policy route-map traffic3
Andy Roberts
Influencing inbound traffic from the Internet is never simple. I have a similar setup and we are using AS path prepending with some degree of success, For example advertise 192.168.1.0 to ISP A and prepend to ISP Y and Z then 192.168.2.0 to ISP Y and prepend to ISP X and Z etc. Not perfect as you may find your prepends stripped out at some point downstream but we certainly saw a reduction in asymmetric routes.
Andy.
Yes, you can use AS Path Prepending to influence the inbound traffic.
By Advertising
Subnet 1 to ISPA without modifying the AS Attribute.
Subnet 2 and 3 to ISPA with prepending the AS.
In that manner if the destination has 3 paths to choose the best from ; then it will choose the path with the smallest AS Path by default. ( which would be ISPA for Subnet 1.)
But before implementing this, please let me know is there any other site were you are using the same AS Number.
And advertising this routes to that site via BGP.
If that is the case then all routes would be rejected... as we have same AS Number for the 2 sites...
