BGP load balancing
Appreciate if you can provide the best configuration guide to achieve load balancing among ISP 1 and ISP 2  between AS 65001 and 65050 according to the attached network diagram.
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages wha2tsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
The "best" load balancing might be achieved by something like OER/PfR, if supported on your equipment.
If not, assuming links are equal, routing equally between the two ASs is probably next best option.  (NB: this will require setting max path to 2 and using the hidden command bgp bestpath as-path multipath-relax.)
In addition to Joseph's suggestion, you can also use bgp dmzlink-bw if your ISP supports it ;-)
Ganesh Hariharan
Hello Ravindu,
Have a look on the below link for BGP case studies for outbound and inbound load balancing.
http://www.cisco.com/c/en/us/support/docs/ip/border-gateway-protocol-bgp/13762-40.html
Hope it Helps..
-GI
