BGP Load Balancing
krunal.lakhani
All,
I would like to understand how to do load balancing using BGP for my below scenario :
1) 2 ISP Link - L2 (MPLS) (500 Mbps + 500 Mbps)
2) Terminated on a single core switch (VSS)
3) BGP connectivity with another switch VSS
I would need to do a BGP load balance to use both link as active active and load needs to be equally devided/balanced.
Please suggest how i can achieve it. If possible share the configuration as well.
do you run eBGP with your providers ?
You could use AS Prepending:
http://showipbgp.com/bgp-configurations/40-cisco/114-4-3-2-cisco-dual-bgp-with-as-prepend-load-balancing.html
or
BGP Load Balancing with Community Strings:
http://showipbgp.com/bgp-configurations/40-cisco/118-4-4-2-cisco-dual-bgp-with-community-string-load-balancing.html
