07-01-2013 07:01 AM - edited 03-04-2019 08:20 PM
I see the topic was discussed many times but I can't find a solution to my problem
so I have two routers, RT1 and RT2, the routers can reach each by two ways:
* a ISP L3 service, the two routers made a ebgp session with the ISP's CE router
* a ISP L2 service, the two routers made a ibgp session between them directly
I can't figure out to made load sharing on the two links, I see ebgp is preferred, I'm looking for the tricks
to tell bgp to use the two links
a example of prefix selection on RT1:
RT1#sh ip bgp 10.132.128.100
BGP routing table entry for 10.132.128.0/22, version 24
Paths: (2 available, best #2, table default)
Multipath: eBGP iBGP
Not advertised to any peer
Refresh Epoch 1
Local, (received & used)
10.132.192.1 from 10.132.192.1 (10.132.97.1)
Origin incomplete, metric 0, localpref 100, valid, internal
Refresh Epoch 1
65000 65500, (received & used)
172.22.190.1 from 172.22.190.1 (172.22.190.1)
Origin incomplete, localpref 100, valid, external, best
on RT2, the network 10.132.128.0/22 is coming from OSPF redistribution
I already tried to add "bgp bestpath as-path ignore", enable multipath on ebgp/ibgp
Thanks for any tips
07-01-2013 08:54 AM
Each of routers, RT1 and RT2, each have a single eBGP link? They share their BGP via iBGP?
eBGP, from RT1 and RT2 are to same or different AS?
How does your outbound traffic get (route) to RT1 and/or RT2?
What platforms (and IOS version) are RT1 and RT2?
07-02-2013 12:39 AM
each router have only one ebgp link
they don't share, at least it's not the goal, the two routers are in distinct locations.
ebgp from the two routers made with the same ISP's AS
RT1 is a cisco router 2901
RT2 is a nexus 5500 with L3 daughter card
thanks
07-02-2013 04:17 AM
Was this intended as an answer to my question "How does your outbound traffic get (route) to RT1 and/or RT2?"
If the two routers are at distinct locations, and the goal is not to share, what kind of load sharing are you trying to accomplish?
07-02-2013 07:14 AM
a diagram would be better
07-02-2013 08:15 AM
Yes, the diagram helps.
Unclear what/why you're trying to load balance from RT1 AND RT2?
If you do it statically, like you're trying to solve, consider traffic from Site A hits RT1 and it routes half the outbound to the ISP and half to RT2. Now if RT2 tries the same, it might take half the traffic received from RT1 and send it to your ISP and routes the other half back to RT1! Normally when you load balance , you don't want to go "sideway", to avoid just this issue.
This is a principle reason why, when AS hops are equal, eBGP is preferred over iBGP.
07-02-2013 08:28 AM
Thanks for the explanation, not sure to understand because AS hops are not equal (ebgp has one more),
so basically I want to load share (50% on each, like round robin) on the two links on each side, any traffic
07-02-2013 04:27 AM
AFAIK, there is one possibility to load share between eBGP and iBGP, but it's avaliable only under the IPv4 VRF address family configuration mode.
See http://www.cisco.com/en/US/docs/ios/12_2sx/feature/guide/fsxeibmp.html for details.
Here is another nice page discussing different BGP load sharing possibilities:
http://stack.nil.com/ipcorner/LoadBalancingBGP/
Best regards,
Milan
07-02-2013 07:20 AM
Thanks milan,
I have already enabled multipath eiBGP on RT2 (Cisco N5K) inside a vrf but ibgp is prefered :
RT2%MPLS# sh ip bgp 172.22.190.130
BGP routing table information for VRF MPLS, address family IPv4 Unicast
BGP routing table entry for 172.22.190.128/25, version 161
Paths: (4 available, best #1)
Flags: (0x804001a) on xmit-list, is in urib, is best urib route, exported
Multipath: eiBGP
Path type: internal, path is valid, is best path
AS-Path: NONE, path sourced internal to AS
10.132.192.3 (metric 0) from 10.132.192.3 (10.132.97.2)
Origin incomplete, MED 1, localpref 100, weight 0
Extcommunity:
RT:3:3
Path type: internal, path is valid, received only
Path type: external, path is valid, not best reason: AS Path
AS-Path: 65000 65500 , path sourced external to AS
10.132.96.1 (metric 0) from 10.132.96.1 (151.164.121.30)
Origin incomplete, MED not set, localpref 100, weight 0
Extcommunity:
RT:3:3
Path type: external, path is valid, received only
Advertised to peers:
10.132.96.1 10.132.192.10
Your link is nice but no setup with mixed eBGP/iBGP
07-02-2013 07:37 AM
I'm afraid you need to get the iBGP and eBGP prefix with the same attributes (AS_PATH length, weight, MED, local preference) to get the load sharing active for the particular prefix?
You could try some route-map applied on the iBGP session I guess?
And/or "bgp bestpath as-path ignore"?
Best regards,
Milan
07-02-2013 07:16 AM
Hi barakat can you send the bgp configurations so that I can help you out. I configured bgp load sharing between 2 ISPs terminated on 2 different routers successfully. Besides what networks you want to advertise to the outside world ?
Sent from Cisco Technical Support Android App
07-02-2013 07:24 AM
Hi rizwan,
You use only ebgp I think with your 2 ISP right ?
the problem is my case is the mix eBGP/iBGP
07-03-2013 06:02 AM
Simply answer is you cant do this simply relying on BGP, you cannot load balance across a Ibgp and Ebgp path (at least without a lot of route maps (per prefix etc) and administritive over head.
You will need to configure / implement one of the following:
Regards Neil
07-03-2013 06:10 AM
References:
http://docwiki.cisco.com/wiki/Performance_Routing_FAQs
07-04-2013 01:53 AM
thanks for your reply neil
I forgot the idea for the moment unitl someone can give me a "simple" solution with bgp
