07-15-2019 01:39 AM
07-15-2019 02:22 AM
for the first question, it is answer 3:
bgp local-as no-prepend replace-as
This is used for eBGP peers, it removes the local AS, and replaces it with another AS number. The eBGP peer needs to peer with the replaced AS number and not the original AS.
07-15-2019 02:56 AM
Hello Ibrahim,
for MSTP PVST emulation allows to have the root bridge either in the MST region or int the PVST region for every PVST instance.
A mix is not allowed.
So the right answers should be:
1) allow the root to be in PVST SW yes
2) Send multiple BPDU for each Vlan
NO. MST is not able to do this . PVST emulation requires consistent root bridge for all instances either in MST region or in PVST region.
3) Disable the edge port if receive a Superior PVST BPDU
yes, as part of the consistency check if for a specific Vlan the PVST BPDU is better then the corresponding MST instance BPDU and the root bridge is in the MST region this will cause a PVST emulation inconsistent state and the whole port is placed in this state.
Hope to help
Giuseppe
