04-02-2012 04:43 AM - edited 03-04-2019 03:52 PM
Hi Everyone,
Good day!
May I asked your expertise in BGP... Our small company decided to have two different ISPs. ISP1 and ISP2.
Now, our network is multihomed but I AM HAVING PROBLEM FROM ISP2. I AM RECEIVING HUNDRED THOUSANDS OF PREFIXES AND IT UTILIZES THE CPU of my router.
Can anyone help me on this... I really appreciate it. Below is my sample config, i am not sure on the route-map i applied in ISP2. Please help!
Sample config...
RTR1#sh run | sec router bgp
router bgp xx80
bgp log-neighbor-changes
neighbor a.a.a.a remote-as aaa <<---- ISP2
neighbor b.b.b.b remote-as bbb <<--- ISP1
neighbor b.b.b.b ebgp-multihop 3
address-family ipv4
no synchronization
network x.x.x.x mask 255.255.248.0
network a.a.a.a mask 255.255.255.252
neighbor a.a.a.a activate
neighbor a.a.a.a prefix-list To_ISP2_BGP out
neighbor a.a.a.a route-map ISP2_OUT in
neighbor a.a.a.a route-map ISP2_IN out
neighbor b.b.b.b activate
neighbor b.b.b.b soft-reconfiguration inbound
neighbor b.b.b.b prefix-list To_ISP1_BGP out
no auto-summary
exit-address-family
ip as-path access-list 10 permit ^$
route-map ISP2_OUT permit 10
match as-path 10
set origin igp
route-map ISP2_IN permit 10
set local-preference 200
Thank you,
Arnold
04-02-2012 04:59 AM
Hi Arnold,
Best thing you can do is to ask your ISP to provide you only default route, if you don't need whole/partial routing table.
Or else, make a route-map which filters out all the routes which you receive from ISP, which you don't want.
HTH,
Smitesh
04-02-2012 05:08 AM
Thank you smitesh... I will consider it as part of my action.
Thank you.
04-02-2012 05:14 AM
Hi Arnold,
Kindly close the thread, if you think your concern is answered, so that other community members don't have to come to this thread and then find it already to be answered..
HTH,
Smitesh
