BGP MED attribute
snarayanaraju
Level 4
Level 4
Hi Friends,
A basic conceptual query. Hope you experts donot bother to help me on this
I know that BGP MED is having OPTIONAL NON-TRANSITIVE attribute. But I also
know that MED is capable of moving to immediate next neighbour AS.
MED is a hint to external neighbors about the preferred path into an
autonomous system (AS) that has multiple entry points
But since it is passing to next AS, How it is catagorized as NON-TRANSITIVE
? Since it is seen in neighbour AS, I thought it should be TRANSITIVE . But
to my surprise it is OPTIONAL NON-TRANSITIVE
Please help me where i have understood wrongly
regards & Thanks in advance
sairam
Reza Sharifi
Hi Sairam,
Non-transitive means if you receive a MED form your neighbor AS, you will not propagate that MED to other ASs.
For example:
If AS-1 is connected to AS-2 and AS-2 is also connected to AS-3, When AS-2 receives a MED from AS-1 it will not advertise that MED to AS-3
Reza
simontibbitts
Hi Sairam.
I think you are getting confused with the term 'transitive' From the Jeff Doyle Routing TCP/IP Volume II book:
"If an optional attribute is TRANSITIVE, a BGP process should accept the path in which it is included, even if it doesn't support the attribute, and it should pass the path on to its peers.
If an optional attribute is NONTRANSITIVE, a BGP process that does not recognize the attribute can quietly ignore the Update in which it is included and not advertise the path to its other peer"
To summarize. TRANSITIVE and NONTRANSITIVE indicates what a router should do with the update if it does not understand it.
Simon
Tharak Abraham
Level 3
Level 3
Hi Sairam,
The MED attribute RECIEVED from a neighboring AS WILL NOT be propagated to other neighboring ASes and thats why its referred to as Optional-Non transitive and not because of the reason that an AS/router advertises this attribute.
