BGP Next Hop
GRANT3779
I'm currently reading through some design book for BGP.
If states the following when talking about how BGP sets next hops -
"For example, if an OSPF prefix is redistributed into BGP, the BGP next hop is not necessarily the BGP speaker doing the redistribution, but rather is the original next hop of the OSPF prefix. Thus, in this case, it is advisable to reset the next hop at the redistribution point to the BGP speaker itself.
For the last sentence, is this achieved by using the next hop self neighbour command or is it talking of something else?
Richard Burts
I am not quite clear on the context but I believe that it would be pointing to next hop self for the solution.
Rick
Rick
yes you are correct it will be achieved by using next-hop-self command.
Case A
R1--OSPF---R2---IBGP-----R3 ( you need to configure next-hop-self  on R2 Towards R3)
Case B
R1--OSPF---R2---EBGP-----R3  ( No next-hop-self required)
I hope this clears your doubt.
Dennis Mink
If the OSPF neighbour is opstream from the BGP router that redistributes OSPF into BGP, which in turn peers to a single BGP neighbour. in otherwords, the path is daisy chained, then by all means, add the next hop self command in there as there is no alternative path anyway
Please remember to rate useful posts, by clicking on the stars below.
