BGP not coming up Nexus 9000
TRACY HARTMANN
Beginner
Beginner
This Nexus seems to have different commands and the BGP is not coming up.   I don't show any neighbors or even like it is trying to come up.
Below is some information about the Nexus and the config
 Software
BIOS: version 08.32
NXOS: version 7.0(3)I4(7)
BIOS compile time: 10/18/2016
NXOS image file is: bootflash:///nxos.7.0.3.I4.7.bin
NXOS compile time: 6/28/2017 14:00:00 [06/29/2017 05:53:29]
cisco Nexus9000 C9504 (4 Slot) Chassis ("Supervisor Module")
Intel(R) Xeon(R) CPU E5-2403 v2 @ 1.80GHz with 16401184 kB of memory.
Processor Board ID FOC21413L60
feature bgp  (is this the only one I need on?  I was only using statics before)
router bgp 64649
log-neighbor-changes
address-family ipv4 unicast
Network 2.2.2.0 /24
neighbor 10.13.252.26
remote-as 64576
neighbor 10.13.252.27
remote-as 64577
Do I need a local router ID defined?
show ip bgp summary
BGP summary information for VRF default, address family IPv4 Unicast
Seems like I am missing something
2 Accepted Solutions
Harold Ritter
Hi @TRACY HARTMANN ,
With NXOS, you need to enable the
under each neighbor.
router bgp 64649
remote-as 64576
remote-as 64577
address-family IPv4 unicast
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
This fixed it thank you for your help.
8 Replies 8
marce1000
VIP Mentor VIP Mentor
VIP Mentor
 - Review this document https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus9000/sw/6-x/unicast/configuration/guide/l3_cli_nxos/l3_bgp.html , check if the licensing requirements are met (too).
 M.
-- ' 'Good body every evening' ' this sentence was once spotted on a logo at the entrance of a Weight Watchers Club !
balaji.bandi
VIP Community Legend VIP Community Legend
You need to provide more information here. is the nexus in vPC ? Do you have VRF ? Do you have neighbor IP reachability?
show bgp all
BB
Georg Pauwen
VIP Master VIP Master
VIP Master
feature bgp
is the only one you need. Try and add the neighbors under the main BGP process rather than the address family:
router bgp 64649
--> neighbor 10.13.252.26 remote-as 64576
--> neighbor 10.13.252.27 remote-as 64577
MHM Cisco World
VIP Mentor
if the neighbor is direct connect then OK if not please share the topology with some more info
Harold Ritter
router bgp 64649
remote-as 64576
remote-as 64577
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
For NKOS the address family can config
1- under router
2- under neighbor
He already config it under router? Or this is bug?
Hi @MHM Cisco World
This is not a bug. NXOS BGP configuration structure is closer to IOS-XR than IOS.
1- The
section under router bgp is used to configure things that will apply to this address family as a whole, such as maximum-path, network statements, etc.
2- The
under the neighbor is to first and foremost activate the address family on the neighbor
(IOS uses neighbor x.x.x.x activate under address-family ipv4 uni)
and secondly it is used to configure parameters related to the specific address family for this neighbor, such as
route-map, prefix-list, default-originate
etc.
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
Recognize Your Peers
