Routing
Don't miss this Cisco Catalyst 8000 offer
Labels
Finding accurate answers to your questions and issues is always gratifying, but what if these answers are shared globally across different languages? The Cisco Community team has been working on a proof of concept (PoC) to take Accepted Solutions in...
Kelli Glass by Community Manager
  • 10271 Views
  • 7 replies
  • 16 Helpful votes
The host for my current server (Windows Hyper-V machine with four or five VMs) that handles my email and web sites is going away. I'm planning on moving that physical server to my house and using DDNS to route that traffic in. Realize this is very lo...
Hi Experts,Basic question regarding the ISIS process. If I have a default config of ISIS between simple two IOS-XR routers:In this case both level-1-2 will form neighbor relationship.RP/0/RP0/CPU0:test1#sh run router isisrouter isis ISIS-COREnet 49.0...
So I've been working on my project and I've implemented vlans nad also router stick.Now I want to block connections between vlans that are not same with extended access list but something does not work..Here are the commands that I've writtenip acces...
Hi All,I have 2 networks connected via OSPF. I need to route the connected networks to a third network via BGP.I noticed that BGP peering is established but no entry is visible on the routing table.Below is an extract of BGP config:router bgp 65200.1...
Ranjita by Level 1
  • 189 Views
  • 10 replies
hi,i'll be changing an ISP/BGP peer. my question is, do i negate first the old bgp router-id or just directly configure/apply the new router-id?do i need to do a "clear ip bgp" to establish the new ISP/BGP peer?router bgp 65123 neighbor 63.21.16.4 sh...
