BGP on Cisco Firewall Cluster
Network Pro
Hello
Scenario - I have two ISP's terminating on Cisco Firewalls (Active/Passive) - is it possible to run BGP between the two ISP's and the pair of Cisco Firewall (failover mode) - I am not how the iBGP will work between them as they both share the same LAN address right?
12 Replies 12
Julio E. Moisa
If your firewalls support BGP you could configure eBGP peerings with the ISP, they will have different AS. I think you want to do something like:
https://supportforums.cisco.com/t5/wan-routing-and-switching/bgp-multihoing-with-firewall-cluster/td-p/2877188
Hope it is useful
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Thanks for the quick reply - so i would not require iBGP peering since its a cluster, right?
You are welcome,
That is correct, basically the cluster is seen as one firewall, the backup firewall has the same configuration like the primary.
Deepak Kumar
If you will configure the ASA in Active-passive mode, then the Passive firewall will not give you the option to configure any BGP or link address (only HA links). The passive firewall will synchronize active firewall configuration.
Only you have to think about how to configure BGP with Both ISP and make transit area.
This link will helpful :
https://www.cisco.com/c/en/us/support/docs/ip/border-gateway-protocol-bgp/23675-27.html
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
hi
wouldnt i be able to configure both links on Primary Firewall? because its a cluster if primary dies wont secondary box take over?
Your network design will be like:
ISP 1 ---->                    -----ISP1------>     Active Firewall   ------->LAN (Inside)
                                     -----ISP2------->
                   Switch L2
                                    ------ISP1------>       Passive Firewall -----> LAN (Inside>
ISP 2 ---->                 -----ISP2------->
If any of ISP or Firewall will down.. another device will take over.
Deepak Kumar
Deepak Kumar,
That is correct, each firewall must have connection with each ISP, now the suggestion is use VLANs between the ISP and the Firewalls through the L2 switch displayed by Deepak, it will provide scalability to your infrastructure.
For example:
               SWITCH
ISP 1 --- VLAN 10 --- Firewall 1
ISP 2 --- VLAN 20 --- Firewall 1
ISP 1 --- VLAN 10 --- Firewall 2
ISP 2 --- VLAN 20 --- Firewall 2
I suggest have 2 switches or a stack of switches to avoid point of failures.
Yes correct this is what i was thinking too
are you saying this wwill work right? any issues of this? only thing is that there will be NO iBGP peer, correct?
Yes, You correct no iBGP peer between firewalls.
Some other suggestions for L2 switch as
Disable the CDP/LLDP
Enable Spanning tree portfast (on ports which are connected to firewalls and ISP)
Deepak Kumar
Deepak Kumar,
The Cluster will be seen as one firewall running 1 BGP only. Something like:
               ISP1
firewall
firewall
                ISP2
But each firewall will have 2 peerings one to each ISP through the VLANs created.
Yep Thanks everyone
You are welcome
