Showing results forĀ
Search instead forĀ
Did you mean:Ā
BGP peering using VRF
Khade Purcell
I am having issues Peering 2 routers with BGP within their VRF. I can accomplish this with Cisco IOS version 12.4 just fine in a simulator but I am unable to peer using cisco IOS 15.1 or on a live catalyst 6800 switch unless I configure an RD. I am new to RD and I'm not an advanced VRF user. How can I establish BGP adjacency on the Catalyst 6800 using the VRF without needing to configure the RD?
Example
************************The following config works fine****************
Cisco 3700 Ver 12.4
#router 1
ip vrf INET
int fa 0/0
  ip vrf forwarding INET
  ip address 192.168.0.1 255.255.255.252
  no shut
router bgp 456
  bgp router-id 1.1.1.1
  bgp log-neighbor-changes
  neighbor 192.168.0.2 remote-as 123
  neighbor 192.168.0.2 version 4
address-family ipv4
  no neighbor 192.168.0.2 activate
  no auto-summary
  no synchronization
exit-address-family
address-family ipv4 vrf INET
  no synchronization
  network 1.1.1.1 mask 255.255.255.255
exit-address-family
%BGP-5-ADJCHANGE: neighbor 192.168.0.2 vpn vrf INET Up peer
#router 2
ip vrf INET
int fa 0/0
ip address 192.168.0.2 255.255.255.252
no shut
router bgp 123
  bgp router-id 2.2.2.2
  neighbor 192.168.0.1 remote-as 456
  neighbor 192.168.0.1 version 4
address-family ipv4
  no neighbor 192.168.0.1 activate
  no auto-summary
  no synchronization
  exit-address-family
no synchronization
network 2.2.2.2 mask 255.255.255.255
exit-address-family
%BGP-5-ADJCHANGE: neighbor 192.168.0.1 vpn vrf INET Up
************************ Swapping router 1 with a a L3 switch running 15.1, The following Doesn't work usless I configure an RD****************
L3 Switch vm IOS ver 15.1
#router 1
ip vrf INET
int fa 0/0
  no shut
router bgp 456
 address-family ipv4
exit-address-family
(config)#router bgp 456
(config-router)# address-family ipv4 vrf INET
% VRF INET does not have an RD configured. <<<< Error Message
ip vrf INET
rd 456:1
  route-target export 456:1
  route-target import 456:1
router bgp 456
     no synchronization
#router 2
ip vrf INET
int fa 0/0
    no shut
router bgp 123
 address-family ipv4
  no auto-summary
  no synchronization
  exit-address-family
  no synchronization
exit-address-family
If you are using mpls, then the rd is required, however when using only vrf lite the rd is not used. So technically, then rd can be omitted. But my guess is that if the equipment is able to run mpls, the ios code is written in away that required you to have a rd configured.
When you are using vrf lite you don't need the route-targets. They are also used in mpls.
/Mikael
to be honest I haven't seen a VRF yet without an RD, and I don't see how the BGP peering is working without it. When you say simulator, which one are we talking about ?
GNS3
/Mikael
Hello
FYI -You dont need to specify route distinguishers for vrf-lite but depending on what L3 switch your are using and applicable i would check what SDM template is being used.
sh sdm prefer
Kind Regards
Paul
