01-27-2021 07:10 AM
We are running a CSR with two tunnel links into a site. We are learning the same BGP routes from each interface because they got to the same place and the remote locations can use either one. That all seems to work. Where I have an issue is that all the routes that are learned seem to be redistrubuing back out into the BGP netowork. So at times this site takes over as the route to remote locations when it is not. For example 10.3.48.0/24 is a remote location address, for some reason this site redistrubutes that route as you can get their from here and then of course it dies because it really can't. Not sure if there is an issue with my BGP config, I thought that BGP did not redistrubte unless you configured it.
interface GigabitEthernet2
description circuit 1
ip address 10.3.72.4 255.255.255.240
negotiation auto
interface GigabitEthernet3
description circuit 2
ip address 10.3.72.20 255.255.255.240
negotiation auto
interface GigabitEthernet4
ip address 10.3.78.1 255.255.255.128 secondary
ip address 10.3.78.129 255.255.255.128 secondary
ip address 10.3.79.126 255.255.255.128 secondary
ip address 10.127.3.254 255.255.248.0 secondary
ip address 10.127.15.254 255.255.248.0 secondary
ip address 10.128.0.254 255.255.0.0 secondary
ip address 172.17.254.254 255.255.0.0 secondary
ip address 10.3.73.4 255.255.255.0
negotiation auto
router bgp 64627
bgp log-neighbor-changes
neighbor 10.3.72.6 remote-as 64538
neighbor 10.3.72.22 remote-as 64539
address-family ipv4
network 10.3.72.0 mask 255.255.255.240
network 10.3.72.16 mask 255.255.255.240
network 10.3.73.0 mask 255.255.255.0
network 10.3.79.0 mask 255.255.255.128
network 10.127.0.0 mask 255.255.248.0
network 10.127.8.0 mask 255.255.248.0
network 10.128.0.0 mask 255.255.0.0
network 172.17.0.0
neighbor 10.3.72.6 activate
neighbor 10.3.72.22 activate
exit-address-family
Also not sure why the 172.17.0.0 won't take the subnet of /16
Tracy
01-27-2021 07:48 AM - edited 01-27-2021 07:50 AM
Hello @TRACY HARTMANN ,
easy part :
because 172.17.0.0/16 is a Class B network that it is the default network mask so it is not shown in configuration
difficult part :
you have two eBGP sessions in addition to the local prefixes injected by network command your router is allowed to send to neighbor A what it has received by neighbor B and viceversa. They also use different private AS numbers and this can make accept some unwanted route.
all you need is to use a concept called filtering by As-path
all local routes have AS path empty before sending
ip as-path access-list 11 permit ^$
the regular expression ^$ means an empty AS path string ""
then in BGP you add
neighbor 10.3.72.6 filter-list 11 out
neighbor 10.3.72.22 filter-list 11 out
and this should fix your issue as only local routes are advertised in all cases even if one neighbor withdrawn a remote prefix
The filter-list uses the configured as-path access-list 11 to allow only locally originated routes to be sent to each eBGP neighbor.
Hope to help
Giuseppe
01-27-2021 08:51 AM
Thanks this makes sense, I will be trying the change tonight since its production and I can't make a change right now.
01-29-2021 07:39 AM
We made the change a couple nights ago and it looks like it did the trick. Thanks for the help.
01-29-2021 08:22 AM
I am happy to know the suggested changes worked for your envinroment.
Best Regards
Giuseppe
