BGP Route filtering methods
Edgar c Francis
 BGP updates can be controlled by using a numbers of different filtering methods. BGP updates can be filtered based on routes information, on paths information or on communities. All the methods will achieve the same results choosing one over the other depends on the specific network configuration.
 You might need to control exactly which routes are advertised or redistribute or which paths are chosen. Advertise only some specific routes to neighbor (security reasons).Redistribute specific routes, preventing routing loops, Path manipulation of some specific routes.
Changing metric and metric-type for specific routes. Changing the administrative distance for specific routes with BGP controlling routes to be advertised to ISP. Control routes to get in to routing table Policy based routing.
lets see the methods of BGP route filtering:
Topology :https://www.internetworks.in/2019/03/bgp-route-filtering-methods.html
Goal:
  • configure the topology as per the diagram.
  • configure EBGP as per the topology and advertise directly connected interfaces
  • configure router 2 to block 30.1.1.1/8 networks. make sure router 2 do not install 30.1.1.1/8 network in its routing table.
  • configure distribution list in order to block 30.1.1.1/8 network.
R1#show ip interface brief
Interface              IP-Address      OK? Method Status                Protocol
FastEthernet0/0        10.1.1.1        YES manual up                    up
Serial3/0                    1.1.1.1         YES manual up                    up
Serial3/3                    4.1.1.2         YES manual up                    up
Loopback0              11.0.0.1        YES manual up                    up
Loopback1              11.0.1.1        YES manual up                    up
Loopback2              11.0.2.1        YES manual up                    up
Loopback3              11.0.3.1        YES manual up                    up
R2#show ip interface brief
FastEthernet0/0        20.1.1.1        YES manual up                    up
Serial3/0                    1.1.1.2         YES manual up                    up
Serial3/1                    2.1.1.1         YES manual up                    up
Loopback0              12.0.0.1        YES manual up                    up
Loopback1              12.0.1.1        YES manual up                    up
Loopback2              12.0.2.1        YES manual up                    up
Loopback3              12.0.3.1        YES manual up                    up
R3#show ip interface brief
FastEthernet0/0        30.1.1.1        YES manual up                    up
Serial3/1                    2.1.1.2         YES manual up                    up
Serial3/2                    3.1.1.1         YES manual up                    up
Loopback0              13.0.0.1        YES manual up                    up
Loopback1              13.0.1.1        YES manual up                    up
Loopback2              13.0.2.1        YES manual up                    up
Loopback3              13.0.3.1        YES manual up                    up
R4#show ip interface brief
FastEthernet0/0        40.1.1.1        YES manual up                    up
Serial3/2                    3.1.1.2         YES manual up                    up
Serial3/3                    4.1.1.1         YES manual up                    up
Loopback0              14.0.0.1        YES manual up                    up
Loopback1              14.0.1.1        YES manual up                    up
Loopback2              14.0.2.1        YES manual up                    up
Loopback3              14.0.3.1        YES manual up                    up
R1(config)#router bgp 650001
R1(config-router)#neighbor 1.1.1.2 remote-as 650002
R1(config-router)#neighbor 4.1.1.1 remote-as 650004
R1(config-router)#network 10.0.0.0
R1(config-router)#network 1.0.0.0
R1(config-router)#network 4.0.0.0
R1(config-router)#end
R2(config)#router bgp 650002
R2(config-router)#neighbor 1.1.1.1 remote-as 650001
*Mar  1 14:39:06.207: %BGP-5-ADJCHANGE: neighbor 1.1.1.1 Up
R2(config-router)#neighbor 2.1.1.2 remote-as 650003
*Mar  1 14:39:29.195: %BGP-5-ADJCHANGE: neighbor 2.1.1.2 Up
R2(config-router)#network 20.0.0.0
R2(config-router)#network 2.0.0.0
R2(config-router)#network 1.0.0.0
R2(config-router)#end
R3(config)#router bgp 650003
R3(config-router)#neighbor 2.1.1.1 remote-as 650002
R3(config-router)#neighbor 2.1.1. remote-as 650004
*Mar  1 14:34:49.651: %BGP-5-ADJCHANGE: neighbor 2.1.1.1 Up
R3(config-router)#neighbor 3.1.1.2 remote-as 650004
R3(config-router)#network 30.0.0.0
R3(config-router)#network 3.0.0.0
R3(config-router)#network 2.0.0.0
R3(config-router)#end
R4(config)#router bgp 650004
R4(config-router)#neighbor 3.1.1.1 remote-as 650003
*Mar  1 14:36:26.991: %BGP-5-ADJCHANGE: neighbor 3.1.1.1 Up
R4(config-router)#neighbor 4.1.1.2 remote-as 650001
*Mar  1 14:36:37.771: %BGP-5-ADJCHANGE: neighbor 4.1.1.2 Up
R4(config-router)#network 40.0.0.0
R4(config-router)#network 4.0.0.0
R4(config-router)#network 3.0.0.0
R4(config-router)#end
R1#show ip bgp
BGP table version is 16, local router ID is 11.0.3.1
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
              r RIB-failure, S Stale, m multipath, b backup-path, f RT-Filter,
              x best-external, a additional-path, c RIB-compressed,
Origin codes: i - IGP, e - EGP, ? - incomplete
RPKI validation codes: V valid, I invalid, N Not found
     Network          Next Hop            Metric LocPrf Weight Path
 *   1.0.0.0          1.1.1.2                  0             0 650002 i
 *>                   0.0.0.0                  0         32768 i
 *>  2.0.0.0          1.1.1.2                  0             0 650002 i
 *                    4.1.1.1                                0 650004 650003 i
 *   3.0.0.0          1.1.1.2                                0 650002 650003 i
 *>                   4.1.1.1                  0             0 650004 i
 *>  4.0.0.0          0.0.0.0                  0         32768 i
 *>  10.0.0.0         0.0.0.0                  0         32768 i
 *>  20.0.0.0         1.1.1.2                  0             0 650002 i
 *   30.0.0.0         1.1.1.2                                0 650002 650003 i
 *>                   4.1.1.1                                0 650004 650003 i
 *>  40.0.0.0         4.1.1.1                  0             0 650004 i
R2#show ip bgp
BGP table version is 14, local router ID is 12.0.3.1
 *>  1.0.0.0          0.0.0.0                  0         32768 i
 *                    1.1.1.1                  0             0 650001 i
 *>  2.0.0.0          0.0.0.0                  0         32768 i
 *                    2.1.1.2                  0             0 650003 i
 *>  3.0.0.0          2.1.1.2                  0             0 650003 i
 *                    1.1.1.1                                0 650001 650004 i
 *   4.0.0.0          2.1.1.2                                0 650003 650004 650001 i
 *>                   1.1.1.1                  0             0 650001 i
 *   10.0.0.0         2.1.1.2                                0 650003 650004 650001 i
 *>  20.0.0.0         0.0.0.0                  0         32768 i
 *>  30.0.0.0         2.1.1.2                  0             0 650003 i
 *                    1.1.1.1                                0 650001 650004 650003 i
 *   40.0.0.0         2.1.1.2                                0 650003 650004 i
 *>                   1.1.1.1                                0 650001 650004 i
R3#show ip bgp
BGP table version is 16, local router ID is 13.0.3.1
 *>  1.0.0.0          2.1.1.1                  0             0 650002 i
 *                    3.1.1.2                                0 650004 650001 i
 *   2.0.0.0          2.1.1.1                  0             0 650002 i
 *   3.0.0.0          3.1.1.2                  0             0 650004 i
 *   4.0.0.0          2.1.1.1                                0 650002 650001 i
 *>                   3.1.1.2                                0 650004 650001 i
 *   10.0.0.0         2.1.1.1                                0 650002 650001 i
 *   20.0.0.0         3.1.1.2                                0 650004 650001 650002 i
 *>                   2.1.1.1                  0             0 650002 i
 *>  30.0.0.0         0.0.0.0                  0         32768 i
 *   40.0.0.0         2.1.1.1                                0 650002 650001 650004 i
 *>                   3.1.1.2                  0             0 650004 i
R4#show ip bgp
BGP table version is 15, local router ID is 14.0.3.1
 *   1.0.0.0          3.1.1.1                                0 650003 650002 i
 *>                   4.1.1.2                  0             0 650001 i
 *   2.0.0.0          4.1.1.2                                0 650001 650002 i
 *>                   3.1.1.1                  0             0 650003 i
 *>  3.0.0.0          0.0.0.0                  0         32768 i
 *                    3.1.1.1                  0             0 650003 i
 *>  4.0.0.0          4.1.1.2                  0             0 650001 i
 *>  10.0.0.0         4.1.1.2                  0             0 650001 i
 *   20.0.0.0         3.1.1.1                                0 650003 650002 i
 *>                   4.1.1.2                                0 650001 650002 i
 *>  30.0.0.0         3.1.1.1                  0             0 650003 i
 *>  40.0.0.0         0.0.0.0                  0         32768 i
R2#show ip bgp 30.1.1.1
BGP routing table entry for 30.0.0.0/8, version 9
Paths: (2 available, best #1, table default)
  Advertised to update-groups:
  Refresh Epoch 2
  650003
    2.1.1.2 from 2.1.1.2 (13.0.3.1)
      Origin IGP, metric 0, localpref 100, valid, external, best
      rx pathid: 0, tx pathid: 0x0
  Refresh Epoch 2
    1.1.1.1 from 1.1.1.1 (11.0.3.1)
      Origin IGP, localpref 100, valid, external
(we are going block 30.1.1.1/8 network by using distribution list)
R2(config)#access-list 30 deny 30.1.1.1 0.255.255.255
R2(config)#access-list 30 permit any
R2(config)#exit
R2(config-router)#neighbor 2.1.1.2 distribute-list 30 in
R2(config-router)#neighbor 1.1.1.1 distribute-list 30 in
R2#clear ip bgp * soft
% Network not in table
let see another method of BGP route filtering. continuing previous configuration :
Prefix-list https://www.internetworks.in/2019/03/bgp-route-filtering-methods.html
EDGER C FRANCIS
0 Replies 0
