BGP route issue
thomuff
Level 3
Level 3
I have two sites connect to an MPLS network through two different POPS  POP C and POP D
Site A redistributes a static route pointing to a vendor router at that location
Site B redistributes a static route pointing to a vendor router at that location.
Both routes are for the same network.
Site A example   192.168.1.1  255.255.255.0 is routing to 192.168.2.1  (connects to POP C)
Site B example   192.168.1.1 255.255.255.0 is routing to 192.168.3.1  (connects to POP D)
After temporary shutdown of Site B, all locations have Site A static route.
We believe that sites connecting to POP C should route to Site A  and sites connecting to POP D should route to Site B
How do  I get site that connect to POP D route to site B?
Hope this makes sense
Giuseppe Larosa
Hello Thom,
what kind of service are you getting?
a L3 MPLS VPN or a L2 VPN ?
Do your routers peer with service provider PE nodes or directly between themselves?
If it is a L2 MPLS VPN you just need to use local preference to have site C to prefer site A route and site D to prefer site B route.
If it is a L3 MPLS VPN it is still possible but you need to use BGP communities and you need to cooperate with service provider.
Hope to help
Giuseppe
