BGP ROUTE_MAP ISSUE
shivlu jain
Level 5
Level 5
i am having 7600 which is rinning with ospf as IGP and bgp peering with my ISP.I want to distribute the routes (10.255.255.252/32 and 10.255.255.10/32) thru route map to my neighbors.
my conf is
ip prefix-list TEST1 permit 10.255.255.252/32
ip prefix-list TEST1 permit 10.255.255.10/32
route-map TEST permit
match ip address prefix-list TEST1
router bgp 65006
neighbor 1.1.1.1 remote-as 65007
neighbor 1.1.1.1 route-map TEST out
my problem is i am not getting the both routes at the oher end.
regadrs
shivlu
Harold Ritter
Shivlu,
You first need to inject these prefixes in BGP via a network statement or redistribution from the IGP (or static). The network statement is usually the preferred approach. Note that the network statement has to match a route in the RIB for that route to be injected in BGP.
router bgp 65006
network 10.255.255.10 mask 255.255.255.255
network 10.255.255.252 mask 255.255.255.255
Hope this helps,
Harold Ritter
Shivlu,
router bgp 65006
Hope this helps,
