BGP: route-map
kozorezdi
Hello everybody,
Please check my config:
conf t
route-map PEER_TEST-out permit 20
match community 1111:43071
set as-path prepend 1111
continue 50
route-map PEER_TEST-out permit 50
   set community 0:1111 0:2222 0:3333 0:5555 0:6666 0:7777 0:44444 0:32323 0:3599 0:77776 0:6876 0:8686 additive
sh run
continue 50
And the most important it works with a jump to 50, but without adding the prepend.
It looks like set-command will be never completed, because it goes after continue-command.
Quite often I need to modify this set of communities (0.*) and it will be hard to do it on every strings: 20, 30,40, etc.
It looks like I can't use a community-name for set community --> set community test1
ip community-list standard test1 0:1111 0:2222 0:3333 0:5555 0:6666 0:7777 0:44444 0:32323 0:3599 0:77776 0:6876 0:8686
I don't see the solution.  Please help me!
Thank you in advance,
Dmitry
Peter Paluch
Hi Dmitry,
Your config looks OK. It is interesting that the as-path prepend does not seem to have any effect. Can you show us the relevant portion of the command show route-map PEER_TEST-out please? Also, how is the route-map used - for inbound or outbound policy? Can you also perform the appropriate show ip bgp X.X.X.X on the appropriate router to see that the route-map really did not have any effect on the AS_PATH?
Best regards,
Peter
Peter Paluch
Hi Dmitry,
Best regards,
Peter
   Hi Peter,
thank you very much for your post. you motivated me to check everything again
first of all, i am using this route-map for out only.  my mistake was using the construction:
match community instead of match community .
so now it is working (only prefixes with cust-routes or internal-routes will be permited and it checks for deny or add some prepends):
ip bgp-community new-format
ip community-list standard no-test permit 9000:43070
ip community-list standard test-one permit 9000:43071
ip community-list standard test-two permit 9000:43072
ip community-list standard test-three permit 9000:43073
ip community-list standard cust-routes permit 9000:4410
ip community-list standard cust-routes permit 9000:4420
ip community-list standard cust-routes permit 9000:4430
ip community-list standard internal-routes permit 9000:4510
ip community-list standard internal-routes permit 9000:4520
ip community-list standard internal-routes permit 9000:4530
route-map TEST-out deny 10
match community no-test
route-map TEST-out  permit 20
match community test-one
continue 50
set as-path prepend 9000
route-map TEST-out  permit 30
match community test-two
continue 50
set as-path prepend 9000 9000
route-map TEST-out  permit 40
match community test-three
continue
set as-path prepend 9000 9000 9000
route-map TEST-out  permit 50
match community cust-routes internal-routes
set community 0:2854 0:6820 0:6858 0:12555 0:13062 0:16020 0:20807 0:34898 0:3565 additive
Thank you very much for your questions! Have a nice day!
